Tutorial: How to use split in Autodesk Inventor?
Small
Tutorial: How to use split in Autodesk Inventor.
    Invoke a sketch on the plane.
    Draw a sketch which will be used for splitting. Here I take an arc. Finish the sketch.
    Click on split.
    Click on "split face".
  5. Step 5:
    Select the face.Click ok.
  6. Step 6:
    This is the result of the above steps. Here only one face is splitted.
  7. Step 7:
    Use the option to split some selected faces.
  8. Step 8:
    Click on "split solid". Select the arc as the split tool. Click ok.
  9. Step 9:
    This is the result for the above steps.
  10. Step 10:
    Remaining in the first option,select "all".
  11. Step 11:
    Select the arc as the split tool. Click OK.
  12. Step 12:
    This is the result for the above steps. The result is same as that of "split solid".
  13. Step 13:
    Click on split bodies. select the direction. click ok.
  14. Step 14:
    This is the result of using split bodies.
Please log in to add comments
