Tutorial - Modeling Container using Surfacing in SolidWorks?
Small
Here is the tutorial.
    Top plane>>Sketch.
    Draw this profile.
    Extrude it.
    Reference geometry>>plane.
  5. Step 5:
    Top plane by 70mm.
  6. Step 6:
    Plane1>>Sketch.
  7. Step 7:
    Draw a circle.
  8. Step 8:
    Exit the sketch. Lofted surface.
  9. Step 9:
    Select the circle and the edges of the extruded surface as the loop using selection manager.
  10. Step 10:
    Tangency to face.
  11. Step 11:
    Click OK. Again Plane1>>Sketch.
  12. Step 12:
    Select the edge and then convert entities.
  13. Step 13:
    Extrude it.
  14. Step 14:
    Front Plane>>Sketch.
  15. Step 15:
    Draw this profile using spline.
  16. Step 16:
    Trim it in half.
  17. Step 17:
    Draw another spline tangent to this one.
  18. Step 18:
    Revolve surface it.
  19. Step 19:
    Trim surface.
  20. Step 20:
    Trim away the outer surfaces.
  21. Step 21:
    Knit surface.
  22. Step 22:
    Select all surface and uncheck gap control. Check merge entities.
  23. Step 23:
    Fillet.
  24. Step 24:
    Select the edge of the extruded-surface2.
  25. Step 25:
    Thicken.
  26. Step 26:
    Select the surface and thicken it outside.
  27. Step 27:
    And we have the basic surface of the container.
Please log in to add comments
