Tutorial - Using cut with surface feature in SolidWorks?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/29274/feed.jpg?1552114776)
Here is the tutorial.
Start SolidWorks in Part mode.
Front plane>>Sketch.
Make a rectangle of these dimension.
Extrude it by 50mm.
Now we have an extruded body.
Under features tab choose reference geometry>>plane.
Choose the front face of the box.
Rotate the box and choose the back box too.
The plane is created in the middle of the box.
Choose Front plane>>Sketch.
Step 11:
Standard views>>normal to.
Step 12:
Draw a arc of 60mm with endpoint vertical to the edges of the box and horizontal to each other and same time the 3rd point at the origin.
Step 13:
Exit the sketch.
Step 14:
Choose front face of the box.
Step 15:
Choose convert entities in the sketch tab.
Step 16:
Select the Sketch1 or arc. Click OK and again OK.
Step 17:
Exit the Sketch.
Step 18:
Choose Plane1>>Sketch.
Step 19:
Choose Normal View then use offset in sketch tab and select the arc.
Step 20:
Keep the default setting and exit the sketch.
Step 21:
Under surfaces tab choose lofted surface.
Step 22:
Select the arc from the upper end points 1 by 1. Click OK and the lofted surface is generated.
Step 23:
Choose cut with surface in surfaces tab.
Step 24:
choose lofted surface and let the direction be upper.
Step 25:
Click OK and we have the cut feature generated.
Step 26:
Choose the lofted surface and hide it.
