Tutorial - Modeling square Head bolt with square Nut in SolidWorks?
Here is the tutorial.
Top plane>>Sketch.
Draw a square of 18mm side.
Extrude it by 7.5mm.
Top face>>Sketch.
Draw a square of 10mm side.
Again Top face and then sketch.
Draw a circle of 10mm dia tangent to the sides of the box.
Extrude it by 50mm.
Bottom face>>Sketch.
Step 11:
Draw a circle tangent to the sides of the box.
Step 12:
Extuded cut. Check the flip side to cut with draft enabled at 60º.
Step 13:
Chamfer.
Step 14:
Select the top edge at 2mm and 45º.
Step 15:
Now we have the body.
Step 16:
After cutting threads.
