Tutorial - Modeling Twisted cutter in Creo Elements aka Pro/E?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/29274/feed.jpg?1552114776)
Here is the tutorial.
Sketch >> Top plane.
Draw a circle.
Extrude it.
Choose Slant Rectangle tool.
Create slant rectangle.
Extrude it and click Remove material. The height be up to next surface.
Click OK and the cut is generted.
Axis tool.
Select circular face and the axis is generated.
Step 11:
While selecting cut feature click Edit >> Pattern.
Step 12:
Defined by axis.
Step 13:
Set the angular extent button.
Step 14:
Increase the number of times to somewhat ~27.
Step 15:
Click OK.
Step 16:
Insert >> Warp.
Step 17:
Select body.
Step 18:
Select Twist tool.
Step 19:
Change the direction.
Step 20:
Input the Angle value.
Step 21:
Click OK and the feature is generated.
