Tutorial - Modeling USB Head in SolidWorks Part 1?
Tutorial by Sudhir Gill
Small
Here is the first part of tutorial.
    Start SolidWorks in Part mode.
    Top plane >> Sketch.
    Draw a rectangle of 32mm x 15mm.
    Extrude it by 7.11mm
  5. Step 5:
    Top face >> Sketch.
  6. Step 6:
    Draw this sketch.
  7. Step 7:
    Mirror it about center line passing through origin.
  8. Step 8:
    Extrude cut it by through all.
  9. Step 9:
    This face >> Sketch.
  10. Step 10:
    Draw a circle of 6.096mm dia at the mid of the center line.
  11. Step 11:
    Extrude it by 13.97mm at 2º draft.
  12. Step 12:
    Select this face >> Sketch.
  13. Step 13:
    Draw a circle of 3.048mm diameter.
  14. Step 14:
    Extrude it by 20.32mm.
  15. Step 15:
    Top face >> Sketch.
  16. Step 16:
    Draw a horizontal center line on this face.
  17. Step 17:
    Draw a rectangle of 14.478mm x 9.906mm at a distance of 4.064mm to right edge.
  18. Step 18:
    Extrude cut it by .508mm.
  19. Step 19:
    Inner face >> Sketch.
  20. Step 20:
    Draw a center line.
  21. Step 21:
    Draw a circle of 2.54mm diameter at origin.
  22. Step 22:
    Offset the center line by 2.54mm in bi-direction.
  23. Step 23:
    Convert these lines to construction geometry.
  24. Step 24:
    Draw a circle of 1.524mm diameter at 8.382 to the right of 2.540mm dia circle.
  25. Step 25:
    Draw a center point rectangle and make its side equal.
  26. Step 26:
    Smart dimension it 1.524mm.
  27. Step 27:
    Draw a triangle using polygon tool.
  28. Step 28:
    Extrude sketch by .508mm.
  29. Step 29:
    Here is second part. http://grabcad.com/questions/tutorial-modeling-usb-head-in-solidworks-part-2
Please log in to add comments
