Tutorial - Modeling USB Head in SolidWorks Part 2?
Here is the second part of tutorial.
Inner face >> Sketch.
Draw these center lines.
Make angle of 50º.
Offset them by .254mm in bi-direction.
Close these and trim away the lines.
Extrude it upto this surface.
Select this face >> Sketch.
Draw a center line and then a center point rectangle at the midpoint of the center line passing throgh origin.
Smart dimension it to 11.938mm horizontal and 4.064mm vertical line.
Offset the lines by .508 inside direction.
Step 11:
Extrude it by 11.938mm.
Step 12:
Step 13:
Draw a rectangle.
Step 14:
Smart dimension it.
Step 15:
Mirror it about the center line.
Step 16:
Extrude cut it by through all.
Step 17:
Step 18:
Draw a rectangle of 1.016mm height coincident to inside edges.
Step 19:
Extrude it upto the next surface.
Step 20:
Fillet tool.
Step 21:
Select all these edges and fillet them by 1.016mm.
Step 22:
Now fillet these edges by 1.016mm.
Step 23:
Step 24:
Draw two center line about the quadrants of the circular edge.
Step 25:
Draw a rectangle to the .762mm of the center lines.
Step 26:
Convert the circular edge.
Step 27:
Trim the circle and the rectangle.
Step 28:
Extrude cut it from offset of 1.016mm and depth of 1.016mm.
Step 29:
Here is third part. http://grabcad.com/questions/tutorial-modeling-usb-head-in-solidworks-part-3
