NASA Handrail Clamp Assembly Challenge
NASA challenges you to design a handrail clamp assembly for The International Space Station!
About this Challenge
NASA is seeking to challenge the GrabCAD Community by sponsoring an open competition where participants utilize the new additive manufacturing capability on the International Space Station (ISS). The competition will be to design a complementary Handrail Clamp Assembly (HCA) which is currently utilized by astronauts to provide rigid mounting locations required in a microgravity environment for normal daily operations. The complementary HCA design will be referred to as the CHAMP (Clamp for Handrail with Additively Manufactured Parts). The printed part will be analyzed to further our understanding of the effects of microgravity on the fused deposition method of manufacturing.
Handrail Clamp Assembly (HCA) Overview
The HCA is currently utilized on the ISS to provide a seat track interface by creating a structural connection on the ISS handrail located throughout the station. It should be noted that the seat track interface is what needs to be reproduced in the CHAMP. The seat track is consistent with those utilized on commercial airlines. The interface does NOT have to be considered a separate feature. It must however provide the interior cross section and access to that interior profile consistent with the provided dimensions so as to be a functional connection point for the mating adaptor (must be at least 1.750” long with 0.785” holes, etc.). The cross section should be considered a smooth and consistent surface. The following picture show the HCA as well as the HCA in-situ.
Addition to NASA GrabCAD Challenge (as of January 22)
The overall function of the clamp assembly is to provide a seat track interface in order to mount hardware onto the handrails. This Challenge is not focused on creating a carbon copy of the existing ISS handrail clamp, but to design a device that attaches to the handrail and provides a seat-track-like interface specifically optimized for 3D printed material. The handrail itself does not need to be redesigned. The existing seat track is metallic and has small features with high strength capability that would be very difficult to replicate with ABS plastic. While a new seat-track-like device could be designed the goal is to design the device to interface with the Stud specified in MS33601, available
here. Please note we understand the spec is outdated, but the NASA interfacing components meet this spec.
The current clamp assembly (shown for reference) has a required kick load of 125 lbf. We understand that this requirement may be unfeasible given ABS material and the size limitations, but try to make the designs as strong as possible. Maximum loads from mechanical properties we have obtained so far from ABS parts made by FDM are as follows:
  • Z Tensile (build direction): 50 lbf,
  • XY Tensile (-45,45 layup): 121 lbf,
  • XY Tensile (0,90 layup): 120 lbf,
  • Flex (-45,45): 359 lbf,
  • Flex (0,90): 323 lbf,
  • Z Compression: 1433 lbf,
  • XY Compression (-45,45): 1316 lbf,
  • XY Compression (0,90): 1457 lbf.
A factor of safety is not accounted for with the listed numbers. Crew tools on the ISS must have a FOS of at least 2.
Seat Track Explanation
We understand that many designs are works-in-progress, but we wanted to make sure that everyone in the challenge was aware of how seat track functions. Please take a moment to watch this video showing how the stud and seat track connect. Your design should allow for the stud fastener to be attached and secured. Thanks again to Philip LaRoach for finding and sharing this video.
Requirements
  • You must include:
    - STL version
    - Description of your design
  • You are encouraged to include:
    - Native CAD file format
    - STEP or IGES version
    - Rendering
  • CHAMP figures of merit:
    The following figures of merit will be used by NASA to determine which CHAMP design is determined as the most successful and is to be printed on the ISS.
    1. Total Material Usage
    a. ISS has established a maximum amount of ABS plastic allowed within the pressurized volume due to outgassing issues.
    2. Number of prints required to complete each CHAMP
    a. Astronaut time is valuable and sparse on the ISS
    3. Hand Rail Connection
    a. Ease of attachment
    b. Ease of removal
    c. Stability of attachment
    - Slippage along handrail length
    - Rotation about handrail
    - Inadvertent disconnect
    4. Seat Track Connection
    a. Consistent with provided dimensions.
  • ISS Additive Manufacturing Capability:
    - Print Volume (inches): 2.36 x 4.72 x 2.36 (X-Axis) x (Y-Axis) x (Z-Axis = extrusion direction or “vertical”)
    - Material: ABS Plastic
    - Nozzle Opening (inches): 0.015
    - Minimum Layer Height (inches): 0.01
    - Print Resolution (inches): 0.04
  • The CHAMP must at minimum meet the following requirements:
    1. Shall be capable of providing a rigid connection to the handrail as defined above.
    2. Shall provide a seat track interface as defined above.
    3. Shall conform to the following sharp edge human factors
    - Exposed edges 0.25 in thick or greater shall be rounded to a minimum radius of 0.12 in.
    - Exposed edges 0.12 to 0.25 in thick shall be rounded to a minimum radius of 0.06 in.
    - Exposed edges 0.02 to 0.12 in thick shall be rounded to a full radius.
    - The edges of thin sheets less than 0.02 in thick shall be rolled or curled.
    4. Envelope
    - Shall not extend beyond 1” from the cross-sectional perimeter of the handrail once installed and considered ready for use.
    - Shall not extend beyond 5” along the handrail long axis.
    5. If multiple parts are utilized, each much connect without the need of additional tools or materials. This applies to assembly, installation, removal and disassembly.
    6. All design models shall be delivered as .stl files with a suitably fine mesh accurate enough to convey design intent (a .stp file will be required from the top three place designs as well).
    7. Directions specifying build orientation shall be provided along with the design models. Axis nomenclature is found below in the ISS Additive Manufacturing Capability section.
Rules
  • ENTERING THE COMPETITION
    The Challenge is open to everyone except employees and families of GrabCAD and the Sponsor. Multiple entries are welcome. Team entries are welcome.
    By entering the Challenge you:
    1. Accept the official GrabCAD Challenges Terms & Conditions.
    2. Agree to be bound by the decisions of the judges (Jury).
    3. Warrant that you are eligible to participate.
    4. Warrant that the submission is your original work.
    5. Warrant, to the best of your knowledge, your work is not, and has not been in production or otherwise previously published or exhibited.
    6. Warrant neither the work nor its use infringes the intellectual property rights (whether a patent, utility model, functional design right, aesthetic design right, trademark, copyright or any other intellectual property right) of any other person.
    7. Warrant participation shall not constitute employment, assignment or offer of employment or assignment.
    8. Are not entitled to any compensation or reimbursement for any costs.
    9. Agree the Sponsor and GrabCAD have the right to promote all entries.
    If you think an entry may infringe on existing copyrighted materials, please email challenges@grabcad.com
  • SUBMITTING AN ENTRY
    Only entries uploaded to GrabCAD through the "Submit entry" button on this Challenge page will be considered an entry. Only public entries are eligible.
    We encourage teams to use GrabCAD Workbench for developing their entries.
    Entries are automatically given the tag "handrailclamp" when uploading to GrabCAD. Please do not edit or delete this tag. Only entries with valid tag will participate in the Challenge.
  • AWARDING THE WINNERS
    The sum of the Awards is the total gross amount of the reward. The awarded participant is solely liable for the payment of all taxes, duties and other similar measures if imposed on the reward pursuant to the legislation of the country of his/her residence, domicile, citizenship, workplace, or any other criterion of similar nature. Only 1 award per person.
    All winners will be contacted by the GrabCAD staff to get their contact information and any other information needed to get the prize to them. Payment of cash awards is made through PayPal. All team awards will be transferred to the member who entered the Challenge.
    We will release the finalists before the announcement of the winners to give the Community an opportunity to share their favorites in the comments, discuss concerns, and allow time for any testing or analysis by the Jury. The Jury will take the feedback into consideration when picking the winners.
    Winning designs will be chosen based on the Rules and Requirements.
    - This Challenge ends on February 17, 2015 (11:59pm UTC).
    - Winners will be announced by March 17, 2015.
    Void where prohibited.
Prizes
$2,000 total prize pool
1st Place
$1,000 cash
2nd Place
$500 cash
3rd Place
$250 cash
4th Place
$150 cash
5th Place
$100 cash
About In Space Manufacturing
The International Space Station’s 3-D printer has manufactured the first 3-D printed object in space, paving the way to future long-term space expeditions. The object, a printhead faceplate, is engraved with names of the organizations that collaborated on this space station technology demonstration: NASA and Made In Space, Inc., the space manufacturing company that worked with NASA to design, build and test the 3-D printer.
This image of the printer, with the Microgravity Science Glovebox Engineering Unit in the background, was taken in April 2014 during flight certification and acceptance testing at NASA's Marshall Space Flight Center in Huntsville, Alabama, prior to its launch to the station aboard a SpaceX commercial resupply mission. The first objects built in space will be returned to Earth in 2015 for detailed analysis and comparison to the identical ground control samples made on the flight printer prior to launch. The goal of this analysis is to verify that the 3-D printing process works the same in microgravity as it does on Earth.
The printer works by extruding heated plastic, which then builds layer upon layer to create three-dimensional objects. Testing this on the station is the first step toward creating a working "machine shop" in space. This capability may decrease cost and risk on the station, which will be critical when space explorers venture far from Earth and will create an on-demand supply chain for needed tools and parts. Long-term missions would benefit greatly from onboard manufacturing capabilities. Data and experience gathered in this demonstration will improve future 3-D manufacturing technology and equipment for the space program, allowing a greater degree of autonomy and flexibility for astronauts.
For more information, visit the website at www.nasa.gov/3Dprinting
349 comments
  • Surajmal
    Surajmal over 10 years ago
    Will Astronaut apply the force to rotate or slippage of clamp?
    Surajmal has uploaded 133 CAD models & has left 382 comments.
  • Jonathan Brazeau
    Jonathan Brazeau over 10 years ago
    Wow, Nasa.....good for you Sara..connections...:P
    Jonathan Brazeau has uploaded 209 CAD models & has left 2121 comments.
  • Tommy Mueller
    Tommy Mueller over 10 years ago
    Double Wow! This is the real deal :) A 3D printed part used by an astronaut on the ISS... That would be some bragging rights for the engineer who tops out on this challenge. I hope to see you there!
    Tommy Mueller has uploaded 224 CAD models & has left 1842 comments.
  • Jonathan Brazeau
    for sure, a really big deal, that 3D space printer has been all over the news lately.....expect some publicity to whoever wins this one. CNN, NY times etc...
  • Jonathan Brazeau
    “The HCA is currently utilized on the ISS to provide a seat track interface by creating a structural connection on the ISS handrail located throughout the station. It should be noted that the seat track interface is what needs to be reproduced in the CHAMP. “
    More details please, is the goal to design the whole mechanism, as shown in blue, with the lever also, or just the track that is mounted to it, opposite the handrail?
    Do the hand rails need redesign or design for 3dp fdm also? I’m assuming you will be keeping the aluminum hand rails intact as they are on the station.
    “The seat track is consistent with those utilized on commercial airlines. The interface does NOT have to be considered a separate feature 1.02” wide and 0.44” tall.”
    What does this mean, can you elaborate? Thanks.
    It must however provide the interior cross section and access to that interior profile consistent with the provided dimensions so as to be a functional connection point for the mating adaptor (must be 1.750” long with 0.785” holes, etc.). The counterbore holes (dimensions removed) are NOT required.
    The “mating adapter”, being the anodized blue gizmo seen in the pictures?
    From what I understand, there are three parts that make up the HCA,
    The Handrail ( oval shaped tube, looks like ano alum)
    The Clamp mechanism ( the part that clamps onto the rail using a lever)
    The seat track (the tracked part attached to the clamping mechanism)
    All of this to be re-designed for 3D printing?
  • Pitso
    Pitso over 10 years ago
    The project description is quite vague, can we have a thorough and well written design requirements especially the first two paragraphs.
    Pitso has uploaded 1 CAD models & has left 3 comments.
  • LYNN Engineered Systems
    LYNN Engineered Systems over 10 years ago
    I agree Pitso. Some type of mechanical requirements would be nice also. Max allowable stress, deflections, required safety factor,etc..
    LYNN Engineered Systems has uploaded 12 CAD models & has left 5 comments.
  • Reza Allahyari
    Reza Allahyari over 10 years ago
    Please put high-quality images. I'm zooming the image is blurred and unclear.
    If possible, please upload more information
    Thank you so much
    Reza Allahyari has uploaded 141 CAD models & has left 1574 comments.
  • Reza Allahyari
    Wow .............
  • Philip LaRoach
    Philip LaRoach over 10 years ago
    cool new contests, I wish I had more time to enter.
    Philip LaRoach has uploaded 40 CAD models & has left 127 comments.
  • Jonathan Brazeau
    Yes, a little vague..
    if my paragraph above wasn't clear, the questions I was asking were:
    1.More details please, is the goal to design the whole mechanism, as shown in blue, with the lever also, or just the track that is mounted to it, opposite the handrail?
    2.Do the hand rails need redesign or design for 3dp fdm also? I’m assuming you will be keeping the aluminum hand rails intact as they are on the station.
    3. There's mention of print time and amount of ABS used due to offgassing concern, What is the maximum allowable print time and amount of ABS???
  • Pablo
    Pablo over 10 years ago
    The description is not very accurate. I understand that the dimensions 1.02x0.44 and 1.750 with the 0.75 holes are for the seat track. The clamp has the dimensions that you want while is under the restrictions and can be adapted to the tube.
    Pablo has uploaded 32 CAD models & has left 28 comments.
  • Pablo
    I was assuming that we had to design both seat track and handrail connections. It would be a good point to be clarified
  • Jonathan Brazeau
    still have no idea what we're supposed to be designing...I guess it's a clamp...lol.
  • Mart Berghs
    Mart Berghs over 10 years ago
    Strange question perhaps, it is possible to do 3D printing without support structures in zero gravity?
    Mart Berghs has uploaded 773 CAD models & has left 1085 comments.
  • Goran Pekic
    Goran Pekic over 10 years ago
    I think this is not possible (printing without support), because the melted plastic is pushed through the nozzle, and then there is the force that will push the plastic aside. this pushed plastic will not levitate in one place... i hope so... :)
    Goran Pekic has uploaded 42 CAD models & has left 267 comments.
  • Mart Berghs
    But out of the nozzle the ABS cools, then it cringe/shrinks. Get stiff and less
    flexibility. Would that not be enough in combination with the nozzle, which also pulls on the cooling filament while printing.
  • Hevi
    Hevi over 10 years ago
    Good questions about printing in "zero gravity", but I think in some cases you must print with support because you need some surface to stick on it... so the support is needed.
    Hevi has uploaded 40 CAD models & has left 468 comments.
  • Hevi
    BTW - can we get the exact T-Groove dimensions?
  • Abhijeet Das
    Abhijeet Das over 10 years ago
    I guess NASA won't disclose any info about their technology on which they have spend a lot of their resources.
    Abhijeet Das has uploaded 23 CAD models & has left 225 comments.
  • Hevi
    The winner will fly there to print this clamp =] ...yayks! :D
  • Abhijeet Das
    haha!! who knows if NASA becomes too generous to send the winner into space!!
  • thinkin3D
    thinkin3D over 10 years ago
    What is the nozzle diameter of the Printer. I think I read somewhere that it only prints in ABS... is that correct. Is there any literature on the printer (hate to Google some bad info).
    Do the clamps need to retain the "C" channel on the backside? Or are they going to be adding mounting points themselves to the Iges file?
    Are there any load requirements, so we can print and test prototypes ourselves?
    Are there maximum print times, or recommended print times? Time is valuable, I can only imagine how valuable it is in orbit :)
    I have more questions, but I'll wait until these are answered first.
    thinkin3D has uploaded 77 CAD models & has left 1898 comments.
  • Hevi
  • Jonathan Brazeau
    Is hardware allowed or is the design to be purely 100% printed..?
  • siemon janssen
    siemon janssen over 10 years ago
    hardware, expect it not. I assume that there are no hardware stores around the corner. NASA, they also take hitchhikers?
    siemon janssen has uploaded 0 CAD models & has left 2 comments.
  • Jonathan Brazeau
    you could have a situation where they bring have a small supply of generic hardware...? really don't know how it works....NASA?
  • Philip LaRoach
    Here's an example of the seat track I found:
    http://www.uscargocontrol.com/Ratchet-Straps-Tie-Downs/Aircraft-Style-Seat-L-Track/Aircraft-style-seat-track-6-ft?gclid=CJv0y9T9p8MCFY17fgodF2UAjQ
    http://www.premier-metals.com/seat-cargo-track-extrusion-rails/
    Is these the correct type? I think one thing throwing people off is there's no image of the track showing the holes.
  • Hevi
    I think we need to design something what is 100% printable. But I was thinking about - maybe they should change rails on the station? For some alu rails like ITEM has.
  • Jonathan Brazeau
    pretty sure the hand rails are out of aluminum, it looks like anodized blue aluminum...
  • Hevi
    Ok, but I was wondering why they need this kind of clamp if they could use something like this - http://img.directindustry.com/images_di/photo-g/aluminum-profile-round-13749-7920568.jpg There is many kind of them. So you have "pipe" with T slot. And now you can mount a lot of accesories to it.
  • Mark Young
    Mark Young over 10 years ago
    It's a handrail first Hevi & I can't see them changing any time soon. :)
    Philip I think you are right. I assume our part provides 1 hole centred over a 1.750” length. We still need the internal dimensions of the channel.
    Mark Young has uploaded 4 CAD models & has left 41 comments.
  • Hevi
    I know it's handrail, but this type could be much more useful... practical... it is my opinion...
  • Philip LaRoach
    I'm assuming this clamp lets them adapt to use seat track attachment hardware on the blue bar system.
  • Michel Schon
    Michel Schon over 10 years ago
    Could we please get all the information with SI-Units!
    Michel Schon has uploaded 3 CAD models & has left 38 comments.
  • Sara Sigel
    Sara Sigel over 10 years ago
    We've updated the page with new information based on your questions. If you don't see an answer to something you're wondering, apologies for missing it. Feel free to point out what needs more clarification. Thanks for all the great feedback and entries so far! Once we get all the details up, we'll start giving some individual feedback, so get your concepts up to allow for more iterations.
    Sara Sigel has uploaded 1 CAD models & has left 1841 comments.
  • Jonathan Brazeau
    what is maximum amount of ABS? allowed....I've asked two times already. :P
  • Philip LaRoach
    Here's a video of the style seat track I think being used:
    https://www.youtube.com/watch?v=J40YcQFLHPk#t=70
  • Philip LaRoach
    Looks like they rails are pretty useful:
    https://www.youtube.com/watch?v=vcos-X1bYiM
  • Jonathan Brazeau
    nice find LaRoach... looks pretty close yes.
  • Philip LaRoach
    looks like there's already info in the community:
    Aircraft Seat Track
  • Jonathan Brazeau
    So is Nasa on this thread at all? What, are they on the moon or something?.................*cough...
  • Hevi
    Can someone explain me the max external dimensions?
  • Hevi
    2nd thing, for 3D printing they need some "slicer"; I would like to know what slicer they are using.
  • keerthi vardhan
    keerthi vardhan over 10 years ago
    I would draw it on a paper to upload this thing
    keerthi vardhan has uploaded 1 CAD models & has left 6 comments.
  • Drew Hood
    Drew Hood over 10 years ago
    Sorry for the delay in responding, please note the update made to the challenge description on 1/22 we hope this will provide answers to most of the comments. We are working through the rest of the comments now and will post additional responses if we feel they were not addressed in the 1/22 update.
    Drew Hood has uploaded 0 CAD models & has left 15 comments.
  • Michel Schon
    Here are my max. external dimensions of the clap in mm:
    Dimensions of the NASA Handrail Clamp
    Could you please answer my questions?
    1. Max. amount of ABS plastic for one print in gram [g]?
    2. The seat track has to be 1.02” (44,45 mm) long?
    3. Are the holes (0,785”) needed in the seat track if the interior cross section can be accessed on both sides?
  • Drew Hood
    This comment was removed
  • ANOUAR BARODI
    ANOUAR BARODI over 10 years ago
    ANOUAR BARODI has uploaded 98 CAD models & has left 1654 comments.
  • b Z.
    b Z. over 10 years ago
    Anyone from NASA, is there a overhang threshold for the ISS 3D printer? Most ABS printers can do up to 45° without support material, but I would like to know if there are restrictions specific to the ISS printer. Thanks.
    b Z. has uploaded 1 CAD models & has left 17 comments.
  • Quincy Bean
    Quincy Bean over 10 years ago
    Joseph: 45 deg overhangs are still our rule of thumb. As part of our experimentation we have steeper angle overhangs but we haven't gotten the parts back to see how well they built.
    Quincy Bean has uploaded 0 CAD models & has left 15 comments.
  • Drew Hood
    Michel Schon:
    1. For this challenge, we are not constraining the print time or quantity of ABS permitted.
    2. Sorry for the confusion, there are no length requirements on the seat track. We had some last minute changes to the images posted that we did not get properly reflected in the written explanation. The device must fit within the Envelope requirements specified above (seat track included).
    3. Yes the hole is needed. Please take a look at the Youtube video and Aircraft Seat Track links above for a visual of how seat track works. Please let us know if you still have a question.
  • Quincy Bean
    Hevi: Slic3r can be used to generate the g-codes. The company Made in Space generated all the g-codes for the parts built so far. They might have their own slicing software but they've also used slic3r.
  • Drew Hood
    Hevi:
    To verbally explain the max external dimensions... take a 1" wide sweep around the external profile of the handrail end view (oval view) now extrude that 5"... that's your max envelope for everything (clamp, seat track, etc.). During installation pieces of the clamp are allowed to travel outside this volume, but once installed all of the device must be within this volume. Perhaps a picture really is worth a thousand words...I'll see if I can get a sketch uploaded to the challenge.
  • Quincy Bean
    Jonathan: I'm not sure off hand what the maximum allowable amount of ABS on the ISS is but what we launched is well under that limit. There is no set time limit, but the longest build so far was just under 4 hours. The printer has it's own filtration and it is also set up inside the Microgravity Science Glovebox which has its own filters so there is no ABS offgassing into the main cabin.
  • Abhijeet Das
    Picture will be nice, but I got your point! 5" extrude of 1" offset of handrail! # Boundary
  • Drew Hood
    Abhijeet Das, exactly! Much more concise, thanks for rephrasing into better CAD lingo.
  • Abhijeet Das
    My Pleasure! and thanks for your answers helped a lot!
  • Michel Schon
    Drew Hood:
    Thanks for the quick answer. But I am still not sure about the length of the seat track: How many holes are needed for the positioning (fixing)? In the video only one hole in needed but other fittings may need more holes?
  • Drew Hood
    Michel Schon:
    The items that attach to the current clamp have the same footprint as the stud in the video.
    **Please note the number of holes (or clearance) needed to install the stud in the video**
  • Jonathan Brazeau
    so from this video,
    But the bolts that will hold the seat track onto the clamps, they're threaded into 3D printed plastic? How is that supposed to work, it won't hold. Am I missing something?
  • Drew Hood
    Jonathan:
    From the HAC overview, "The seat track is consistent with those utilized on commercial airlines. The interface does NOT have to be considered a separate feature." So in the video you can disregard the thru holes in the track used for mounting. The track can be integrated or attached to your design however you see fit, but it must all be 3D printable. Hope this helps. Let me know otherwise.
  • Drew Hood
    Also please note "Addition to NASA GrabCAD Challenge (as of January 22)" section above about the strength of ABS material and expectations for the seat track itself.
  • Jonathan Brazeau
    But if the track is 3D printed, it won't stand up to the forces involved.....that's why it's made from machined aluminum....will the naughts be attaching heavy objects to it or just small objects to it?, actually I guess weight doesn't matter haha, it's space.....but we could talk in terms of forces I guess then. Like if the attached object was hit by something with much more mass, the 3D printed track would snap..... if this was already discussed and explained, I apologize, a lot of info to talk into account.
    Jon-
  • Drew Hood
    Yep you're on the right track! We know it won't be as strong as the aluminum track and could be the weak spot of all the designs, structurally... but that's part of the challenge :)
    Are there novel ways to reinforce the track?
    What kinda of loads can it take?
    What kind of performance can we get out of a 3D print optimized design?
  • Jonathan Brazeau
    ok, helps a lot. thanks.
  • Joshua Scheringer
    Joshua Scheringer over 10 years ago
    excuse the dumb question, i dont really understand the +- tolerances are they supposed to be included for example if .8 + .020 should the measurement be .8 or .82 or in between? im a just for fun user and havent been to school for any of this stuff but im excited to participate in such a big challenge.
    Joshua Scheringer has uploaded 23 CAD models & has left 98 comments.
  • keerthi vardhan
    Do we have to upload 3D images on our selves or this website do it for us ?
  • Abhijeet Das
    No keerthi, you have to design it yourself in any CAD tool such as Solidworks, Catia, Pro-E, etc. By this website we share our work to all the fellow engineers. And also please ask challenge related questions here, for any doubt about this website you may ask Sara Sigel
  • keerthi vardhan
    so we have to upload 3d pictures ourselves right.
  • Abhijeet Das
    Yeah along with the CAD file!
  • keerthi vardhan
    And can we download it i mean the cad tool.and i cant design it on myself .so what should i do now?i dont know what to do now
  • keerthi vardhan
    And what is a cad file
  • keerthi vardhan
    i have downloaded glovius software.how can glovius be useful to my project.please give me a brief note.becauce i am just a student.i cant understand these computer knowledge.
  • Ivo Alberti
    Ivo Alberti over 10 years ago
    Why do not you see my details I posted?
    Long before some others that I see?
    Perchè non si vedono i miei particolari che ho postato ?
    Molto tempo prima di certi altri che vedo ?
    Ivo Alberti has uploaded 348 CAD models & has left 4625 comments.
  • Mart Berghs
    @Ivo Alberti. I think you deleted the "add tags" field. This must contain "handrailclamp".
  • Ivo Alberti
    Ok , singlefonts , many thanks !
  • Jonathan Brazeau
    what is the preferred method for mass reduction, reduction of infill or more standard methods like, holes, pocketing etc.
  • Rashiga Walallawita
    Rashiga Walallawita over 10 years ago
    Hi how close can we print a gap? is it equal to the print resolution?
    Rashiga Walallawita has uploaded 16 CAD models & has left 47 comments.
  • Quincy Bean
    Jonathan:
    For the bigger parts we've built so far we've used sparse infill to cut down material use and print time, but we haven't evaluated how infill percentage effects material strength yet. Short answer, we have no preferred method yet.
  • Quincy Bean
    Rashiga:
    Gaps can be wider than the resolution. Once we get the parts back to study we'll have a better estimate of what kind of gaps it can do with accuracy but for now let's say maybe not much more the 1/2 inch. It may be able to do longer gaps with domes or arches.
  • Jonathan Brazeau
    So, would that mean we would have to radius the edges of the clamp itself? if it's printed on a flat bed, it's better if the bottom edge is left without a radius...Can this be explained a little further..?
    Hey Jonathan,
    Thanks for the reply, lets say that I want to print a hinge. What should I use as the minimum gap between the parts of the hinge? Because too much gap would create a play. Hope my question is clear :)
  • Jonathan Brazeau
    @ Rash, .025" gap is what I use and is recommended as a standard across the board, but it goes on a printer by printer basis. That's what I used for my parts and they come out perfect, not too much play, not too stuck....they will be a little stuck, you just break them free and then they will pivot, move rotate, whatever.
    for snug fit against a defined dimension, I use .014-.016", or about .4mm. But again, that's printer specific. So let's say I'm printing a rod which I want to have a nice sliding snug fit in a hole that is EXACTLY 1" ID, then I design my printed part with .985" OD or (1"-.015").
  • Philip LaRoach
    I have a question for the group, I've posted two entries and the second is just a variation of the first. Do you guys feel it would be better to combine these? The concept is the same between them.
  • Jonathan Brazeau
    Phil, up to you. Usually if you go out and tangent into something significantly different then you would upload that as a second entry.... if you're just making small mods to an existing model, keep it all under one submission.
  • Jonathan Brazeau
    @ Nasa, are we allowed to modify the dimensions of the seat track for greater strength, more depth etc.?
  • Niels
    Niels over 10 years ago
    I've a question about the units, just to be certain.
    1. Is the drawing of the beam in inches?
    2. For which area are the loads mentioned for the ABS parts? inch squared?
    Niels has uploaded 0 CAD models & has left 1 comments.
  • Sedzy
    Sedzy over 10 years ago
    I believe I have all the information I need to start a design. However, is this challenge valid to Canadian residents? If I'm not able to be a valid contestant, I'm not going to bother...
    Sedzy has uploaded 0 CAD models & has left 2 comments.
  • Hevi
    Thanks for answer.
    Another question - what about ABS shrinkage factor? What is your plan? You will print every STL file as it is or you will add your ABS shrinkage factor and then you print it?
  • olle olofsson
    olle olofsson over 10 years ago
    Why are the given measurements in inches, it makes me wonder if its really NASA'S challenge since it's a well known fact that NASA uses the metric system. not being a douche just being curious.
    olle olofsson has uploaded 39 CAD models & has left 22 comments.
  • Danny Tasmakis
    Danny Tasmakis over 10 years ago
    @ olle, why don't you PM one of the NASA jurors they are GC members :)
    Danny Tasmakis has uploaded 55 CAD models & has left 652 comments.
  • Quincy Bean
    Jonathan:
    The requirements for the radiused edges are in accordance with HFIT (Human Factors Implementation Team) requirements so sharp edges should be radiused. In general, yes, it is better to have a completely flat bottom surface however the machine on the ISS prints directly onto a tray and at least one edge needs to have a radiused or angled corner in order to pry it off the plate. For taller parts it's not that much of an issue though.
    For the seat track dimensions you can modify them as needed, as long as it can interface with the stud dimensions shown on the everyspec link.
  • Quincy Bean
    Rashiga:
    Sorry, I misunderstood your question. Features less than 0.04" is about where this printer starts losing accuracy. For moving parts it can go as low as about 0.01" and still have a gap. It may be a little stuck but with some effort the parts will break apart.
  • Quincy Bean
    Niels:
    Yes, the beam dimensions are in inches.
    The loads we listed are general maximum loads we found from mechanical testing of ABS samples made by the FDM process.
  • Quincy Bean
    Hevi:
    I haven't noticed shrinkage from this printer, we'll probably print as is.
  • Quincy Bean
    Olle:
    This is the first I've heard about it. I think it really just depends on who's doing the math and what units they prefer to work in.
  • Hevi
    Quincy Bean Thank you. Do you accept projects which require support system for printing?
  • Hevi
    Quincy Bean 2nd thing, can we get back to max allowed ABS amount? Jonathan is right, we should have this information, much more it was mentioned in requirements.
  • Abhijeet Das
    A request to new entries please don't repeat or copy the work of old entries as it will effect the Honor code we follow all the time. There is always something creative to make for a single task! Thank You
  • Hevi
    Abhijeet Das Open your thought... :)
  • Abhijeet Das
    Some of the entries (I won't mention the Engineers name) are having a lot of similarities to the old entries. Its just an request which if followed then good and if not then I don't have any problem. Just many of the Engineers submitted great design Entries and I don't wish others to simply copy and make alteration. Just a thought!
  • Hevi
    Abhijeet Das +1 mate! :( I hope judges will take care of this, or at least will check whos entry was first on GC :/
  • Abhijeet Das
    I hope so Hevi, Also I don't mean any disrespect to any fellow engineers in GrabCad !
  • Drew Hood
    @Hevi and Jonathan
    For this challenge we are not constraining the print time or quantity of ABS permitted. As mentioned in the figures of merit section we are interesting in how much ABS is used to print ones CHAMP design, but there is no "max allowed amount" for the CHAMP. An example to help clarify, the less ABS the design uses means that more CHAMPS could be printed, while staying under ISS established ABS limits. Hope this helps.
  • Jonathan Brazeau
    So basically we're shooting for least material, highest strength yield...like in most industries..Ok, sounds good.
  • b Z.
    Abhijeet Das, I'd like to comment on this. I have been working on a design since this competition launched on the 20th of January. Today someone uploaded a design that has many things in common with the design I've been working on. When I upload my design it will appear as though I've copied and altered another already uploaded design, but in reality I've been 3D printing, remodeling, and refining my design to best meet the requirements. I'm not trying to nit pick but giving the competition a deadline but then displaying entries before the deadline makes the competition about speed rather than the quality of the entries. This does not seem like the best method for running a competition, especially in the context of NASA.
  • Abhijeet Das
    Joseph Corsi I really appreciate your way of working for this competition, it's really good but not all the Engineers participating in this event have that particular resource to refine their design in your manner. I and many of the engineers used software as the only tool to design and optimize the Champ model for NASA. But using 3D printer will give you satisfaction to your design. NASA needs the best design and also we want to deliver them the best but you should keep in mind its a challenge so if what you say is true then it could be taken as point that you might have copied some features from the already submitted entry. Best way to prevent that is to submit some proof of some sort or submit your idea in paper sketch before hand. No doubt NASA experts will scrutinize each and every designs and will select winners wisely. Also those who did 3D printing of their designs, I really praise there effort for achieving satisfaction.
  • Quincy Bean
    Hevi:
    Currently ISS Operations do not allow support material to be printed with the part. The printer only has 1 extruder tip anyway. I'm not sure if that restriction will be lifted in the future but for now it poses a risk to ISS crew. I apologize if that wasn't made clear in the requirements.
  • Hevi
    Quincy Bean 3Thanks, but... I wanted to say that you can print support with the same printer nozzle and same material. It is just an option in slicer software. The point of my question is - let's say Elena prints something and slicing software adds some kind of support >>> http://tinyurl.com/nmlcr5o <<< so now she needs to remove it;is this kind solution acceptable?
  • Joshua Scheringer
    similar concept isnt important, if two people make a similar design one will still be better than the other. its also about who executed the design best ie there are only so many ways to clamp a rail
  • Abhijeet Das
    agree!!
  • Jonathan Brazeau
    I've been competing in quite a few competitions, mostly here on GC and others and there are a few factors to consider, but it's a sketchy topic for sure...
    One thing I try to do to lock in a design is put up a sketch as soon as I can outlining my thoughts and the direction I want to go in. Like Josh says, there's often only so many ways to design something so it comes down to EXECUTION, PROCESS, QUALITY, PRESENTATION and often times, if they're similar enough, submission date.
    You can usually tell when someone waits until the end of the contest to "snipe" an existing design, add improvements to it etc. basically just mooching off others process and work.
    There's a difference between that, and finding inspiration from another design and building off of that. BUT again, it's a sketchy area at best, depends on what is being designed also.
    With something like this, a clamp design....variation in design is pretty tough to achieve, you can expect more overlap. It's going to come down to who posted what first along with the other factors I mentioned above.
    Good luck.
  • Hevi
    I will not comment this "copying" whole thing... :/ But BTW... some entries are out of this space :)
  • Hevi
    Nahh... I will add some comment... Jonathan I do almost same thing, I "lock" some concept by posting my entries. It is almost always "work in progress" project. But when you are working on some new designs someone else is improving your WIP project. You show the path how you were thinking and someone adds few things (sometimes obvious) and you are done :/ Is it fair?
  • Jonathan Brazeau
    I'm not going to repeat, read above.
    This one is tough because there are only so many ways you can 3D print a clamp :) + all of the narrow criteria.
  • Abdelmoumene
    Abdelmoumene over 10 years ago
    Please waht the requqired forces that this clamp should resist.?
    Abdelmoumene has uploaded 0 CAD models & has left 8 comments.
  • Kamen Rusev
    Kamen Rusev over 10 years ago
    99 entries. This shows how much the people cares about space exploration...and 22 days to the end!
    Kamen Rusev has uploaded 56 CAD models & has left 249 comments.
  • Francisco Inglés
    Francisco Inglés over 10 years ago
    Hello. How can we submit an team-entry ? Thanks!
    Francisco Inglés has uploaded 0 CAD models & has left 8 comments.
  • Sedzy
    Can anyone tell me if this Challenge is open to Canadian residents please?
  • Abhijeet Das
    Why it won't be open for Canadian Resident?? Well read the rules regarding entering the competition mentioned above!
  • Quincy Bean
    Abdelmoumene and rsahak:
    Consider the max loads listed as the requirements. With a factor of safety of 2 the required loads would be about half of the listed loads. The kick load requirement of 125 lbf is a general requirement for ISS items that might get kicked by astronauts. We realize that for ABS, 125 lbf might be unfeasible but make it as strong as you can. But, considering that a kick would most likely exert a compressive or flexural force (I can't imagine a kick exerting a purely tensile force) 125 lbf might not be that far out of reach.
  • Sara Sigel
    Sedzy GrabCAD Challenges are open to international submissions. Seeing ideas from around the world is one of the best parts! Challenges are void where prohibited, see our Rules section.
  • 3D concept
    3D concept over 10 years ago
    Has anybody found themaximum amount of ABS plastic allowed within the pressurized volume due to outgassing issues. I must be blind as I cannot find it.
    Helppppp
    3D concept has uploaded 2 CAD models & has left 15 comments.
  • Jonathan Brazeau
    Reg,
    Read up a few posts, NASA is saying their is no max amount of ABS, shoot for best strength vs.material.
  • Hevi
    Quincy Bean Thanks, but... I wanted to say that you can print support with the same printer nozzle and same material. It is just an option in slicer software. The point of my question is - let's say Elena prints something and slicing software adds some kind of support >>> http://tinyurl.com/nmlcr5o <<< so now she needs to remove it; is this kind of solution acceptable?
  • 3D concept
    Has anybody found the Axis nomenclature where is the ISS Additive Manufacturing Capability section.
  • Philip LaRoach
    If you're using SOLIDWORKS and you'd like to know the build envolope of your part, here's a video showing a trick to find the bounding box.
    http://cadcamstuff.com/3684/solidworks-bounding-box-best-underrated-2013-feature/
  • Matteo Nocchi
    Matteo Nocchi over 10 years ago
    How should I use the maximum load specs expressed in lbf? I expected at least a psi. Moreover: could you better explain the "kick load" requirement, is it a 125 lbf force applied to the object in a random direction or what? Thank you for your attention.
    Matteo Nocchi has uploaded 1 CAD models & has left 2 comments.
  • Alberto Beretta
    Alberto Beretta over 10 years ago
    looking projects most seem very fragile for the features required ... who did load tests and analysis of rupture of the projects? results that you got?
    I did try the static load of 1000 Nm
    Alberto Beretta has uploaded 26 CAD models & has left 178 comments.
  • Muhammad Fadlil Adhim
    Muhammad Fadlil Adhim over 10 years ago
    what is the material of the pins?
    Muhammad Fadlil Adhim has uploaded 4 CAD models & has left 7 comments.
  • Sean
    Sean over 10 years ago
    I cant help but think of a large cable tie and a saddle part would do the job here!
    Sean has uploaded 4 CAD models & has left 41 comments.
  • Pit
    Pit over 10 years ago
    is this challenge closed for non americans?
    Pit has uploaded 25 CAD models & has left 106 comments.
  • Mark Fuller
    Mark Fuller over 10 years ago
    Can you provide a source for the metal tube or is it a custom extrusion? Really would like to make a cool Shadow box with the clamps in it :-)
    Mark Fuller has uploaded 7 CAD models & has left 10 comments.
  • Mark Fuller
    Sharp Edge Human Factors & 3D Printing-
    Working on my design I have came into some issues with Fillets on Edges. Due to the Nature of 3D printers, Fillets are very hard to print on the Bottom Edge of a print with out supports in the Z direction. Fillets are very easy to print on the XY plane. Would it be possible to Cut in a 45-60 Degree Chamfer and Fillet the upper part?
  • Philip LaRoach
    @nasa you have metnioned maximum force that the fdm part can handle. But there is no detail on the size of the part you people have done the test. Is it for 1 in X 1 in section?
  • Jonathan Brazeau
    Hello,
    Quite a few entries, I'd just like to point out to everyone participating, this part is something that will be 3D printed, in space. There are some limitations with 3D printing on the ground, let alone in space....I would say that 80%+ of the designs uploaded would not be feasible or would require support material, and even then probably wouldn't work just due to complexity. This is not a challenge to design a clamp for NASA, the challenge is to design a 3D PRINTED clamp, big difference.
    Do yourself a favor and research about 3D printing before spending all that time making a fancy design and uploading 5 versions of it.
    To start with, remember that the 3D printer builds off of a flat surface, secondly, imagine the layers being added line by line, any angle past 45 degrees won't work without support material (you can bridge gaps, and this can work quite well here on earth, but even then it requires a bit of knowledge and testing, and that's not to mention zero G).
  • Hevi
    For sure NASA has lot of test printing ;)
  • Juan Gonzalez
    Juan Gonzalez over 10 years ago
    I have a question. The measurements of 1.379 in. and .754 in. of the blue oval in the picture provided are of the handrails? They seem to be a tad bigger when looking at the pictures of the astronauts grabbing on to them. Maybe is just the perspective in the picture. Thanks.
    Juan Gonzalez has uploaded 0 CAD models & has left 8 comments.
  • Trevor Sheen
    Trevor Sheen over 10 years ago
    I have uploaded my design using the "Submit an entry" button, however my design has not appeared in the entires, but it has appeared on my profile. Did I upload it incorrectly? Or should I have used another method?
    Trevor Sheen has uploaded 1 CAD models & has left 11 comments.
  • Mart Berghs
    @Trevor Sheen, add "handrailclamp" to tags field. Which you probably erased.
  • Trevor Sheen
    https://grabcad.com/singlefonts thanks, yes I deleted the tag :) all good now
  • #David
    #David over 10 years ago
    @ Hugh: This is a design COMPETITION, not a design collaborative effort. If it was then everyone contributing to this challenge would be rewarded, and that quite isn't the case. Also, I'm not crazy about the fact that you seem to be encouraging designers to borrow ideas from other entrants to be used in their own designs and find that way of thinking a bit marxist where a person's creative and intellectual property is concerned. It be wonderful to remove any sort of designer ownership from the designs that have the most likes, take what you want, and combine them into a winning design, wouldn't it. Will be interesting to see what you come up with as I would imagine you are planning on entering...right?
    @ Jonathan: I'm not sure why you feel the need to take on the role of paternal 3D printing guru here. I've been 3D printing for over 5 years now on all kinds of machines and am quite happy letting the competition make as many mistakes as they like.
    #David has uploaded 43 CAD models & has left 334 comments.
  • Jonathan Brazeau
    Dave, just giving some advice to entrants, that's all. Just seems like people aren't grasping that this needs to be 3D PRINTED, it's not a, design a clamp for the hell of it, assignment.
    And, now that I've been 3D printing for a while, I realize the limitations. I see how some of the designs I made for 3D printing competitions before, were way off the mark because I didn't fully understand the process, not having a printer.....
    With your 3D printing experience, even more so you'd have to agree, most of these designs would be pretty hard to print. But whatever, great eye candy anyway. No complaints there.
  • Philip LaRoach
    The challenge has hit the halfway point and there's 200+ entries, I wonder how many there will end up being? I think this one will be an interesting one to judge.
  • #David
    @jonathan, just apologize for not PMing me about getting your own 3D printer : )
  • Jonathan Brazeau
    lol, oh you didn't you know? got a lulzbot taz4 a few months ago :) have been printing ever since :P thing is sick.
  • Jonathan Brazeau
    one question I had for the community, especially the 3D print croud....... how to do FEA analysis for an infilled 3D printed part....20, 30, 40% infill...etc.?????
    use a less dense material value? will it still be accurate?
    anyone.......anyone.....anyone.....(Ferris Beuller)
  • Flaviano Crespi
    Flaviano Crespi over 10 years ago
    @Jonathan;
    Comment dit Monsieur de La Palice, "il est beaucoup mieux d'imprimer avec une imprimante à $ 10,000 plutôt que celui de 1000", :)
    What level do you think is the printer of the ISS? could exceed the limits that you have shown us?
    Flaviano Crespi has uploaded 365 CAD models & has left 1689 comments.
  • Ioannis Skarlatakis
    Ioannis Skarlatakis over 10 years ago
    @Jonathan Have you ever came across the fracture mechanisms??? If so then you would agree that the infill structure is like internal flaws in a body. Singularity problems will not allow for a converged FEA solution. Plus in any case you will try to mesh such a complicate structure it will take forever. Nevertheless you can try to simplify your study with more than a couple of ways.
    (AND NOT WASTE YOUR TIME) ;D
    1- Quick act print a specimen similar to the one we use to determine the tensile strength and get the response in different directions (If you are aware of composite material analysis you know what I mean). Then use these data to build a material from scratch that will give similar response. Test and converge your simulation according to the real life testing results.
    2-ANOTHER WAY try to analyse first your model considering it as an ideal uni-body. After being sure about your results and knowing the area of the max. stress you can try to transfer the stress to a small sample pattern of the infill structure. Do not expect to run and get answers on something very complex for the first time. This is a very long conversation and you will need to take in to account many assumptions.
    But do not forget your big advantage!!! You already have a printer and you can cross-check any FEA results.
    Of course even after all you will still have to consider some statistical error as nothing is perfect even when you 3d printing something. ;P
    Happy to go dipper in this subject if anyone else is interested... Good Night Guys!
    Ioannis Skarlatakis has uploaded 25 CAD models & has left 428 comments.
  • Jonathan Brazeau
    hey Ioannis, thanks for the reply..for sure, just looking for a rough estimate, not looking for a super detailed FEA, just something to present and show where the forces are acting....PM sent :)
  • Sean
    Where should one start when wanting to learn FEA? I understand its not a simple process.
  • Jonathan Brazeau
    start running...and don't stop.
  • 3D concept
    David, thanks for your comment, I have also noticed some designs seem very if not too similar, as for tensile strength a part made in gravity environment and a part made in a weightless environment will probably be different in the z plane, also the make, color, and extrusion temperature of the filament will change the results.
    Good luck to all.
  • Jonathan Brazeau
    looking into FEA analysis right now, getting the hang of it, I've never played with the simulation feature that much but it's blowing my mind, it is incredible cool! there's got to be a way to cheat it to get a more accurate reading for an "infilled" part, what about using a different density, like for wood or something? has anyone experimented with this?
    No much time to go through this properly until weekend...
    However, if you don't analyse dynamics or not consider the gravitational force when conducting an FEA analysis the density is not part of the equation. I hope you get why?! ;D
  • Juan Gonzalez
    Does Anybody know if the position of the seat track has to be the same as in the one from NASA's original HCA design (On top of the rounded side of the handrail)? Somebody made a comment on my project regarding that.
    Clarification will be greatly appreciated. Thank You.
  • Jonathan Brazeau
    not sure if this is appropriate to post here, but I can offer printing services for contestants who want to test print their designs...... PM me if you're interested.
  • Jonathan Brazeau
    hey guys, a little bit of learning for people new to the limitations of 3D printing...
    design your pins printed horizontally, not vertically.....duh right :)
    https://www.youtube.com/watch?v=QeI88668h54&feature=youtu.be
  • Tommy Mueller
    We should keep this NASA thread for the challenge requirements, and not for solicitation of 3D printing or YouTube videos. That's my opinion. Good luck everybody
  • Jonathan Brazeau
    The purpose of the video is to let people know not to print hinge pins in the Z direction. I'm using my model to demonstrate this........There shouldn't be a problem with this.
  • Tommy Mueller
    Uh huh, okay. There's just a lot of information out there on the interwebs which is more reliable than what I learned from that vid.
    However, it looks like we use the same peripheral, Razor Nostrmo? That part was cool :)
  • Jonathan Brazeau
    "Not reliable"
    Not sure what you mean? Can you elaborate.......It's a pretty straight forward video explaination a design flaw in the way I printed my design....I'm sharing so others will learn, incorporate this fact into their designs etc. etc. I don't claim to be a pro at making YouTube vids, they're fun to do though. Yes people can search the
    "interwebs" but at the end of the day, I'm sharing what I've learned during this design process, and its more of a specific and targeted video to this competition, than what you could find online from a general search. I'm sure some eople will found it helpful, if you didn't like it, don't watch it. Simple.
    Did anyone else find it helpful?
  • Michel Schon
    I understand Jonathon! I think it is great that he tells people that a lot of the designs can't be printed and how to change that!
    Could we get back to Juans Question :
  • Tommy Mueller
    @Jonathan, you didn't quote me right. "More reliable" is what I said. You need to have an eye for details in this trade...
    but I digress, your information is useful, thanks for sharing
  • Gerard O'Donoghue
    Gerard O'Donoghue over 10 years ago
    Jonathan,
    I found your video helpful and interesting. It is great to see engineers being helpful to each other in a task such as this. Not everyone has a 3D printer to test their ideas.
    Michel, Juan,
    I have assumed that the track is supported from the rounded side of the rail.
    Structurally this is the section of the rail that can take the most load.
    Like a Universal beam in structural engineering, the long axis will perform better for bending and stress.
    Perhaps NASA can confirm this?
    Gerard O'Donoghue has uploaded 43 CAD models & has left 80 comments.
  • Jonathan Brazeau
    @ Michel and Gerard, thanks guys for the feedback, means a lot. Hopefully it will help influence your direction and avoid any time wasting. Wish I could do it in other languages but I'm limited to English and French at present.
    Feel free to PM me any quick questions about the 3d printing process also, Ilol do my best to answer them.
    Enjoy the challenge!
  • Juan Gonzalez
    Thanks Gerard
  • Ivan Pankratov
    Ivan Pankratov over 10 years ago
    @Jonathan, Thanks fo the demonstration. Would be interesting to compare two sames pins one printed along its length, another perpendicular.
    @Quincy Bean, Rephrasing what Rashiga Walallawita already asked you:
    You mentioned "Maximum loads from mechanical properties we have obtained so far from ABS parts"..."Z Tensile (build direction): 50 lbf,"
    What was the cross section area of the specimen you mentioned, 1 in x 1 in?
    Ivan Pankratov has uploaded 4 CAD models & has left 21 comments.
  • wolfgang gutleb
    wolfgang gutleb over 10 years ago
    hey Folks, i got a question i can't get an answer out of the specs provided. can the Printer on the iss do Support geometry or is geometry dependent on the Extrusion axis. as far as i saw the Printer just had one extrussion head?
    wolfgang gutleb has uploaded 21 CAD models & has left 303 comments.
  • ruben_s
    ruben_s over 10 years ago
    To Ivan Pankratov:
    according to ASTM D638 tensile bar has cross section of 13mm x 3.2mm.
    ruben_s has uploaded 123 CAD models & has left 595 comments.
  • Jonathan Brazeau
    @ IVAN, that's what I am doing.....or I wanted to do until my printers hotend went caput....awesome how mechanical problems always happen at the worst times... :)
    parts are in the mail, hope they arrive in time.
    the pin will be much stronger printed sideways, horizontally, if you search the "interwebs"....*ehem... you'll find that it's pretty common practice to do that for critical parts, it's the downside of printing FDM, there's always work arounds though. Normally you would just use a bolt anyway :).
  • Jonathan Brazeau
    NASA, can your space printer do bridging? please advise. Wouldn't bridging come out great because of zero G?
  • 3D concept
    @ Jonathan if your asking the question it means the results are not certain, if the results are not certain the risk of a failed print is higher, if the the risk of a failed print is higher then why do it ? Bridging happens because pieces are badly designed.
  • Tim Moss
    Tim Moss over 10 years ago
    If I am reading this correctly, the print resolution is 0.04", but the specification for the stud hole is 0.785 +/- 0.005" (MS33601). This tells me that the printer cannot create this feature accurately. Am I missing something?
    Tim Moss has uploaded 1 CAD models & has left 5 comments.
  • ruben_s
    What is the modulus of elasticity (Young's Modulus) of the material ???
  • Tim Moss
    @Reg, Thanks for the clarification. I miss read this information. "ISS Additive Manufacturing Capability:
    - Print Resolution (inches): 0.04"
  • Ivan Pankratov
    @rsahak Thanks! But if we take 13mm x 3.2 mm and i am not wrong we only obtain ~13 MPa, which is not terrible, compared to other results from 3D printers: http://www.3ders.org/articles/20140228-open-source-3d-printed-parts-often-stronger-than-proprietary-versions.html
  • ruben_s
    To Ivan Pankratov:
    According to Mamadapur thesis, average tensile strength for TN4 specimen is only 14 MPa. (page 65)
    https://repository.tamu.edu/bitstream/handle/1969.1/ETD-TAMU-2545/MAMADAPUR-THESIS.pdf?sequence=1
  • Ivan Pankratov
    @rsahak Very interesting, and nice foto on page 9. But Mamadapur thesis date from 2007 and B. M. Tymrak paper, the website is refering to, date from 2014. It seems that technology has evaluated, like they show in their paper a lot depend of printer model.
  • ruben_s
    To Ivan Pankratov:
    Yes of course.
    1. For example, how to define the density of manufactured part which obviously depends from printer's settings (air gaps and etc).
    2. Now, I am in doubts that without Young’s moduli and Poisson’s ratios for each axis will not be possible to define and therefore to move to simulation process???
    Good luck.
  • #David
    @folks at NASA. Hi, I 'd just like to know if there is an ideal printing time range for the device that your looking to attain. Under 1 hour, between 1 and 2 hours, not over 3 hours, etc. I ask because I can print a device out as strong and resilient as you like or as fast as you like. However, having some sort of "printing time frame" value will greatly help with my calculations and determining the final FDM 3D printing parameters, thanks!
  • Juan Gonzalez
    Probably not significant, but does anybody know the the offset of the hand rail.
  • 3D concept
    Good question I was wondering the same thing
  • #David
    @folks at NASA: What I meant by my above comment was that if I had an idea of an ideal printing time range, I can correctly modify my entry file as well as provide the correct 3D printing parameters that would be required when printing out the device e.g. # of shells, wall thickness, infill%, etc. This will help me strike a good balance between the device's strength and the print time it takes to create it.
  • Drew Hood
    @Gerard O'Donoghue: The current clamps contact the oval handrail on the curved section, however the direction of the load affects which axis, short or long, is being loaded.
  • Drew Hood
    @wolfgang gutleb: You are correct, the printer is "geometry dependent" and only has one extrusion head.
  • Drew Hood
    @#David: We are not taking print time into consideration for this challenge. Please focus on strength, not build time.
  • Andrew Diehl
    Andrew Diehl over 10 years ago
    @Quincy Bean, Drew Hood - Can you set the extrusion path width your printer uses, and can you specify the number of loops (perimeters) around the hatch fill?
    If not, what are those settings on your machine?
    Andrew Diehl has uploaded 2 CAD models & has left 5 comments.
  • Jonathan Brazeau
    I'm using 30%, 3 shells on test mockups, 3D printed stuff is pretty weak until you get up into 80+% infill. My honest opinion, for something like this, probably should be 100% infill. Just think about it, you have little small plastic ledges (T Slot for the seat track) where the bolts fit into, a part that's normally CNC aluminum. Putting a load on those bolts is going to put ALOT of force on those thin ledges, even at 100% infill, I could see them ripping with more than 20+ lbs of force. I was going to test this out and post a video, but I have to wait for parts for my printer....:(
  • Quincy Bean
    @Jonathan: Bridges are on of the things we're experimenting with so we're really not sure yet how it will handle bridges. I would suggest keeping the bridge to about 1/2 inch. Arches or domes would probably work really well too.
  • Quincy Bean
    @ Ivan: The tensile bars were about 4 x 6 mm. Flex were about 4 x 10 mm. Compression were cylinders about 12.35 mm in diameter.
  • Jonathan Brazeau
    haha, awesome, that's interesting. I would think bridging wouldn't be an issue in zero G, and if that's so, then you'd basically be looking at a discovered advantage to 3D printing in space!!!!
  • Quincy Bean
    Andrew: In general 1 perimeter is used and the infill is solid. If a sparse infill is used it is generally 3 perimeters and 3 solid layers on top and bottom. The extrusion path width is generally between 0.4 and 0.45 mm.
  • Andrew Diehl
    @Quincy Bean: Thanks!
  • Gerard O'Donoghue
    @Drew Hood,
    Thank you for the response.
    Good to know for sure, bad news for the loads on the ABS track :-)
  • Robert Dietz
    Robert Dietz over 10 years ago
    I have a question about the stud...In the youtube video the stud has a dual circular base...Is this the type on board the ISS as shown in my rendering? Or is it a singular base? Obviously my design would depend on the answer although I have a few ideas for single base studs as well.
    Robert Dietz has uploaded 6 CAD models & has left 38 comments.
  • Robert Dietz
    I believe incorporating the stud into the design is the key to obtaining optimum strength so more information would be appreciated.
  • Drew Hood
    @ Robert Dietz: Yep the "dual circular base," same foot print as in the video. Hope this helps.
  • Juan Gonzalez
    can we get a .stl version of the stud.
  • ruben_s
    @Quincy Bean:
    For ABS plastic, please publish the following mechanical properties:
    - Young's modulus
    - Poisson's ration
    - Shear modulus
  • Dennis Pak
    Dennis Pak over 10 years ago
    @Quincy, Drew:
    In the “Seat Track Explanation” section it states “Your design should allow for the stud fastener to be attached and secured.” I just wanted to verify that the mounting adapter will always have an L-track stud that is secured with a nut, and never the spring-loaded clip type of fitting that is captured by the 0.785” hole but is otherwise loose and can rattle in place. Thanks.
    Dennis Pak has uploaded 1 CAD models & has left 17 comments.
  • Drew Hood
    @Dennis Pak:
    It is hard for me to say "never," but for this challenge the assumption of a rigid nut type faster is an acceptable assumption. Please take note that even with the nut attachment the washer beneath the nut still interfaces with the 0.785" hole. The sliding along the track is not really prevented by friction, but by mechanical interference with the 0.785" hole.
  • Sean
    Oh O! Only just read the comment about no support material. Best make a few alterations!
  • Julian Groeli
    Julian Groeli over 10 years ago
    @Nasa Folks:
    Is there a minimum clearance distance spec between the ISS interior wall (that the hand rail is mounted to) and the nearest rounded surface of the hand rail? From the image it looks like it's about 2 inches. Please confirm. Thank you!
    Julian Groeli has uploaded 8 CAD models & has left 38 comments.
  • b Z.
    @Drew Hood
    Is it safe to assume the nut type fastener used on the ISS uses a washer of approximately the same size as the washer shown in the video, i.e. a washer ≈ 1.125" in diameter and ≈ 0.125" thick? These dimensions do not include the portion that interfaces with the 0.785" hole.
    The photographs of the current hand rail clamp and seat-track seem to indicate this is true.
    Thanks
  • Jack Poon
    Jack Poon over 10 years ago
    Is there additional clearance or tolerance we should add in addition to the tolerances given in the drawings? My experience with 3D printers is that there is an additional clearance we have to account for due to the accuracy capabilities of the 3D printer itself.
    Jack Poon has uploaded 1 CAD models & has left 1 comments.
  • Jonathan Brazeau
    NASA@ Your print volume is stated as 2.36"(Y), 4.76"(X), 2.36"(Z)....
    With the overall envelope as stated:
    4. Envelope
    - Shall not extend beyond 1” from the cross-sectional perimeter of the handrail once installed and considered ready for use.
    And 5" along the rail...
    These envelope specs exceeds the print volume? Can you elaborate, Please advise ASAP, thank you.
  • Jonathan Brazeau
    Yep, nevermind. Just never paid attention to the build volume specs...EEEk. Luckily I'm still good.
  • Jonathan Brazeau
    @ NASA, crazy glue allowed?
    I'm guessing acetone fusing is out of the question..... :P
  • Roger Couture
    Roger Couture over 10 years ago
    There should be a numbering of the proposals to reach it more easily.
    Roger Couture has uploaded 183 CAD models & has left 820 comments.
  • wolfgang gutleb
    as mr.Drew Hood mentioned before.....the focus is on strenght. some seem to have ignored the requirements and material specs at all. at least that will shorten the evaluation process. this is, for good, not a drawing contest.
  • ANOUAR BARODI
    Toooooooooooooooooooooooooooo................. much great entries !!!!!!!!!!!!
  • cristofa
    cristofa over 10 years ago
    ... and so many totally different solutions to one simple problem
    cristofa has uploaded 1 CAD models & has left 3 comments.
  • Juan Gonzalez
    I made two studs for testing my design. Hopefully somebody benefits from them. Just to be clear, I made them as accurately as I could, they might not be exactly as the ones NASA uses. I believe stud3 is more accurate. https://grabcad.com/library/studs-for-nasa-challenge-1
  • bedonskij
    bedonskij over 10 years ago
    Hi all, this is my solution, hope you like it! what do you think? anyway great chellange!
    NASA HCAC Bedonskij
    bedonskij has uploaded 8 CAD models & has left 3 comments.
  • Ernesto Chavez
    Ernesto Chavez over 10 years ago
    Down to the last 12 hours now. Good luck to all the participants.
    Ernesto Chavez has uploaded 4 CAD models & has left 83 comments.
  • wolfgang gutleb
    also good luck to all the creative minds!
  • Jeremiah Hansen
    Jeremiah Hansen over 10 years ago
    NASA has gotten it's money's worth for variety! Good luck to all.
    Jeremiah Hansen has uploaded 1 CAD models & has left 3 comments.
  • Robert Dietz
    You are not kidding, amazing designs for the price.
  • Winston Jennings
    Winston Jennings over 10 years ago
    I predict over 500 entries. Good luck to all!
    Winston Jennings has uploaded 279 CAD models & has left 879 comments.
  • Clix
    Clix over 10 years ago
    After i sowed all this huge party i decided that i couldn't miss it :), a lot of creativity and crazy wonderful ideas...this time i struggle to keep up with the music :)) ...so good luck to you all!!!
    Clix has uploaded 15 CAD models & has left 325 comments.
  • Tommy Mueller
    10 minutes!
  • Winston Jennings
    C'mon, 500 baby...
  • Ernesto Chavez
    7 minutes to go!
  • Mark Young
    Well done everyone!
  • Winston Jennings
    491. This was a very competitive contest. Best wishes to all!
  • Winston Jennings
    492. One more to the mix!
  • Juan Gonzalez
    Only 8 away from 500. Best wishes to all!!!
  • #David
    Good luck everyone and thanks to NASA for what has turned out to be an exciting challenge and opportunity. Almost 500 entries, Wow! BTW-if anyone is interested I've uploaded a video showing how we do 3D printing in da' hood, lol
  • Jori Isohanni
    Jori Isohanni over 10 years ago
    I can not see my entry at the list, I think I accidentally left the challenge tag off the description. Should I do something about it? Uploaded the model 20 min before challenge closed.
    Thanks for this awesome challenge, I signed to grabcad just for this.
    Jori Isohanni has uploaded 3 CAD models & has left 5 comments.
  • Robert Dietz
    If it weren't for so many great designs I would have been happy with my first entry, it just goes to show how great this design forum really is. Even in the corporate world I couldn't imagine pooling together such talent and pushing them to such a level of competitiveness without millions invested in development.
  • Bailey Morgan
    Bailey Morgan over 10 years ago
    I believe the winners design will be so simple its funny
    Bailey Morgan has uploaded 5 CAD models & has left 5 comments.
  • Jonathan Brazeau
  • Robert Dietz
    I did see that PDF it had slot dimensions but nothing on stud height, nut height, or washer dimensions...I just went with round numbers...
  • Jonathan Brazeau
    stud dimensions are there guy, right underneath the slot ??? everything else you can just wing.
    file:///C:/Users/Stormtrooper/Downloads/MS33601B.PDF
  • wolfgang gutleb
    so now wer'e gonna seek out new challenges, new participation.... to boldly design what noone else designed before. up up and away...shwooom
  • Francisco J. Erenas Rivas
    Francisco J. Erenas Rivas over 10 years ago
    It has really been a pride to work for NASA, thanks.
    I do not think you win any awards, as there are very good designs, but if I would like to know that since I've been in the standings, just for personal satisfaction.
    I hope it is possible to know, thank you very much GRABCAD.
    Francisco J. Erenas Rivas has uploaded 41 CAD models & has left 84 comments.
  • #David
    ...I just uploaded a video of me busting my ass doing pull-ups (real ones) on my entry.
  • Jonathan Brazeau
    NO SELF PROMOTION IN THIS THREAD! only I am allowed to do that! :P
  • Jonathan Brazeau
    I'm joking ofcourse. Just watched your video, should have left it unedited, would have been hilarious! should have put a matress down or something :)
  • #David
    hah, you know what you have to do now right? hehe
  • #David
    just wear a helmet...it's not my knees that hurt right now.
  • Jonathan Brazeau
    lmao.
    no way hosay
    I stop short of putting my safety on the line for this clamp, that's what we pay the astronauts to do, just hope they made sure to pack plenty of space band aids!
    Jonathan Brazeau has uploaded 209 CAD models & has left 2121 comments.
  • Dan Jewell
    Dan Jewell over 10 years ago
    492 Complicated entries for one simple part? Wow Gotta love engineers...lol
    Dan Jewell has uploaded 11 CAD models & has left 16 comments.
  • 3D concept
    So Jonathan you like the V5 ?
  • Jonathan Brazeau
    Jonathan Brazeau over 10 years ago
    yep. looks like it would work.
  • 3D concept
    I hope nasa decide to test it, I would love to know how resistant it really is but only testing will show the real figures
  • Jonathan Brazeau
    ah, well, gotta build yourself a little test rig and test it yourself, giv'r a little tough lov'n :)
    oh.... and don't forget the safety glasses *winks.
  • Jonathan Brazeau
    no, not sure how NASA will do it, they've stayed pretty low key on this thread.
    has anyone seen this video??? Jerry test's out NASA's space wrench.....they should have come to GrabCad for this, we would have killed it.
    https://www.youtube.com/watch?v=mvr9a4aZlmU
    love nerdgasm!
  • Ivo Alberti
    I did not understand if he changed the parameters of the press, from the video, or only the material ...
  • Philip LaRoach
  • Michel Schon
    No News?
  • Ben Ewing
    Ben Ewing over 10 years ago
    Hi everyone. The finalists for the NASA Handrail Clamp Assembly Challenge have been released! Let us know your favorite: https://grabcad.com/challenges/nasa-handrail-clamp-assembly-challenge/results. Next we will be ranking them based on the CHAMP Figures of Merit and let you know how they perform.
    Ben Ewing has uploaded 1 CAD models & has left 298 comments.
  • Roger Couture
    The criteria are always obvious only for the judges! It is the law of the competitions.
  • Matt
    Matt over 10 years ago
    I totally agree with Robert. I need to say that the chosen designs are good and easy to print but the usability...
    Matt has uploaded 9 CAD models & has left 5 comments.
  • Vadim Romanovich
    Vadim Romanovich over 10 years ago
    One concern that I have with some of the test results is that the printed rail and the printed clamp are printed with the same layer orientation. The steps amplify the clamping results. That is why I printed my rail on its side so that the print layers are not skewing the results and more accurately represent the aluminum rail.
    Obviously I think the flex gripper should be considered: Flex gripper
    I would also suggest you take a look at these great entries:
    nasa clamp 2
    NASA CHAMP with Fast Twist & Lock
    G clamp using the lock stud
    CHAMP Clamp
    One-Piece Shell Clamp
    Vadim Romanovich has uploaded 12 CAD models & has left 84 comments.
  • Jonathan Brazeau
    @ Rob, kicking them off the rail can be applied to any plastic clamp that had to meet their specs, even if it was injected molded. It's sort of implicit :) You're talking about replacing a CNC component that's thin to begin with, with a weaker material, plastic. That was the whole challenge, the whole point was to design the best and strongest clamp within the parameters given, to atleast come close to matching the strength of the original materials and design...I don't think anything thought we could beat CNC machined metal lol :)....that was fun part, seeing how CLOSE we could get!
  • Jonathan Brazeau
    @ NASA, trusting your judgement on the picks, can't imagine how hard it was. I appreciate making finals. I feel really good about my design and I have no worries that it will perform to spec for your personal testing! Actually curious to see what it's limitations are as I didn't have a chance to push it too it's maximum.
    Lotta hard work, lot learnt, all in all a great challenge for me personally, one of my favorites to date.
    Thanks!
  • Jonathan Brazeau
    Ya well I hear ya. And um, well I guess I'll thank you for the indirect promotion and compliment... I usually try to refrain from commenting on other designs if I'm part of the finalists...:)
    Um, let me put it this way, I think there a few in the finalists that are promising, but out of the 490, there were also atleast 50 that could have easily worked well.....but makes it tough when you have so many good entries right...just gotta trust the client's judgement, they know what they want. But I guess if one of the clamps breaks, causing an astronaut to hit a switch which then sends the ISS into a catastrophic re-entry orbit and it crashes down to earth, it's our problem too :p
    Speak up and place your votes guys!
  • Robert Dietz
    Yes I understand the design and maybe the rendering is a little lacking, is this a rendering contest? I can do pull ups off of any one of my entries while beating them with a hammer in any direction and was not even considered so maybe it is just a gimmick?
  • adam
    adam over 10 years ago
    scratching head and going "wow", I guess I need to buy a 3d printer to explain concept on youtube .......... ;-)
    adam has uploaded 3 CAD models & has left 8 comments.
  • Philip LaRoach
    Philip LaRoach over 10 years ago
    Congrats to all the finalists! This was a great challenge, I really thought I had a chance when my design went front page on grabcads community page and I got 53 likes. I guess the lesson for me is to work on my presentations, solid CAD isn't enough when you have so many strong competitors.
    Here's the link just in case maybe the judges meant to include mine and missed it :)
    NASA CLAMP
    Philip LaRoach has uploaded 40 CAD models & has left 127 comments.
  • Robert Dietz
    I apologize for my rant just feel very let down, good luck to all!
  • Jonathan Brazeau
    +1 Rob.
  • Yoto Yotov
    Yoto Yotov over 10 years ago
    Успех на всички :) беше ми приятно че участвах :)
    Yoto Yotov has uploaded 14 CAD models & has left 37 comments.
  • Isabelle Gayot
    Isabelle Gayot over 10 years ago
    3d printing rule number one OVERHANGS need support material, if you look closely at the runners up they all need support to print. some of the best designs that can really be printed with no support and respect the print orientation rules for strength are not included, Why ??? Does NASA and grabcad really understand 3d printing or are the results influenced by other parameters, if that's the case progress will be slow, I suggest that NASA and "made in space" take a closer look at the results.
    Isabelle Gayot has uploaded 0 CAD models & has left 5 comments.
  • adam
    agree Isabelle, and design for assembly and robutness left out. al you can say is "what are they thinking?"
  • adam
    you need to extrude the "NASA" logo in your design and put a bitmap of the earth in the background. you'd be one up on everyone else
  • Isabelle Gayot
    Yes I think you have found the answer, but if that's the future for space travel, we are not going far soon. It's a shame that real engineering is being taken over by little details and NASA suprised me with the results. Not to mention " made in space" who are supposed to be experts on 3D printing.
  • adam
    I want to be an astronaut hammering pins in a hinge assembly......
  • adam
    I didn't get enough "likes" LOL
  • Winston Jennings
    I think for these challenges, finalists are selected mainly on what the judges find appealing or cosmetic. Anyone else agree?
  • Isabelle Gayot
    Ah shiny, NASA written in big letters, I wonder how much money will be wasted on all these little details, Is this really the future ? I had faith in grabcad but it looks like real engineering has no future in this world. As you said a bitmap of the world and a big logo NASA is all you need to become the best engineer.
  • Isabelle Gayot
    Just been an analising the runners up, Adam you are right "not enough likes" it seems that NASA and "made in space" are more influenced by "Likes" than usability and productivity, what a shame, 3d printing requires an aproche to design that is different from conventional machining and I really was convinced that NASA would take this into account, not the case apparently.
  • Jeremiah Hansen
    I think the "shiny design and rendering" outweighed practicality. I do want to point out that Champs v3.03 uses the exact same principle and base design as mine: Compression Clamp and was posted about 27 hours afterwards. It is much better presentation. I am not saying he copied it, but his design certainly wasn't unique in the class. I find it odd that is the quote given for the choice. Given I placed my focus on the strength, as required, I feel mine should at least be tested with his to prove the concept. They should provide the weighting charts they used to pick the designs as it would help people with future efforts.
  • Jeremiah Hansen
    I meant to say Champs v3.03 is better presentation than mine, although the concept is not unique to his.
  • Isabelle Gayot
    Can we have some real results based on 3D printing and usability, NASA stop looking at the renderings and start printing, you may have some nasty surprises
  • Robert Dietz
    I agree
  • adam
    I think the judges should be questioned. it's blatant liberal diversity political correctness BS results. the judges are all "yes" men/women in corporate America who have "no clue" . they are an example of exactly why I retired. LOL
  • MARCELO A. MEJIA COBO
    MARCELO A. MEJIA COBO over 10 years ago
    Hi everyone. Congratulations to the finalists. Very good looking entries.
    We have put a lot of time an effort to the challenge and I am sure there are a lot of us disappointed with the decision.
    Anyway, I would like to officially request to the jury the important aspects that each of the selected projects have to be on that list.
    I consider that a respectful approach to the almost 500 entries to the challenge and that will also help us to give feedback to finalists
    Thank you in advance.
    Regards,
    Marcelo A. Mejía Cobo
    P.D.: My entry:
    https://grabcad.com/library/reuleaux-triangle-nasa-champ-v1-0-and-v2-0-latest-2
    MARCELO A. MEJIA COBO has uploaded 0 CAD models & has left 2 comments.
  • adam
    hands clapping for Marcelo.......
  • #David
    Congrats to all the finalists and thank you NASA for sponsoring this exciting challenge. Myself and others hope you've enjoyed your experience here and hope you come back soon to give us more opportunities to design and create. I do however, have a few concerns about the finalists, some theories on their functionality, as well as the "uniqueness" that seems to be shared by a few of the entrants. Always the curious and fevered mind, I am currently printing them all out to see if my elementary assumptions are correct.
    In any case I, like most of the folks here at GrabCad, am always trying and hoping to improve both my engineering skills as well as my creative ones and enjoy getting feedback both positive and negative about my projects in the hopes that I may actually win one of these things one day. Particularly what I may be doing/have done wrong as well as what makes my particular model stand out. That being said, while I never expect to win any of these things, I do to some degree expect to do well, especially if I get significant positive feedback on what I consider a solidly designed, engineered, and functional entry. In this case, I can't quite figure out what it was that I did or did not do to not be considered a finalist. If there was something that I missed in the spec or designed incorrectly, or if you just thought it to be plain ugly, I wouldn't mind one of you guys at NASA letting me know. I would greatly appreciate it, thanks!
  • Robert Dietz
    Pretty sound arguments here. Although I feel orientation is trivial as it can be turned very easily, and even the seat track is an easy modification I would consider an easy fix. What was stressed is strength, particularly 125lb kick with a FOS of 2, you would think that would be the first weeding out criteria. These were your specifications which I feel I achieved and I see a few others have as well yet appear to have been overlooked. "The current clamp assembly (shown for reference) has a required kick load of 125 lbf. We understand that this requirement may be unfeasible given ABS material and the size limitations, but try to make the designs as strong as possible"
  • Gerard O'Donoghue
    In any challenge like this there are obviously going to be disappointed engineers.
    But the judges seem to have made life difficult for themselves.
    Take for example one criteria,
    The CHAMP MUST AT A MINIMUM meet the following requirements:
    3. Shall conform to the following sharp edge human factors
    - Exposed edges 0.25 in thick OR GREATER (THAT IS EVERY CORNER) shall be rounded to a minimum radius of 0.12 in.
    - Exposed edges 0.12 to 0.25 in thick shall be rounded to a minimum radius of 0.06 in.
    - Exposed edges 0.02 to 0.12 in thick shall be rounded to a full radius.
    - The edges of thin sheets less than 0.02 in thick shall be rolled or curled.
    This should have been an easy criteria to utilise to check each submission.
    If there are sharp edges or corners they cannot be accepted.
    After that whatever is left is accessed for strength, etc….
    Now take a look at the finalists.
    A very interesting challenge and well done to everyone who took part.
  • 3D concept
    Robert you are correct if the part is turned in the XY plane, the Z axe is always the weakest as it no longer uses the physical strength of the material but sticking or gluing strength, all of the chosen designs except 1 are printed with the axial pins in the z axis so they may work once or twice but the axe would give eventually. I agree that the seat rail could easily be modified but any good design would have also taken into account the seat rail strength and used this to it's advantage. Therefore modifying this now would change the physical properties of the champ for the better or the worst. For example the design CLIPPY how could this be modified for the bolt used ???? or the PT handrailclamp this would need one end opening up for ISS bolt to be used weakening it considerably.
    One last comment.
    NASA has standards that are very very strict because
    1 they put people lives at risk and
    2 they must have an international compatibility between parts.
    This means that even the most mundane dimension or feature becomes very important, so how could they chose entries that need serious modifications before they can use them ??? it makes no sense at all. Many of us engineers were happy to see a real competition coming from a sentinel in the engineering field I personally feel let down by the current results . Maybe we should enter a beauty contest next time instead of racking our brains for nothing.
  • 3D concept
    It would be nice if grabcad could give us some explanations on all of this as it seems a lot of good engineers feel let down.
  • Kamen Rusev
    I have an Idea! There is more space agencies that work with NASA on ISS. European, Russian ,Chinese... Will be good to hear their opinion :) They will use same clamp, right ?
    Hi all again,
    Looking at the review note "...Did we leave anything amazing off the list? See something we should know about? Let us know in the comments!"
    To the members of the jury, I would like to challenge you to find any entry with a One-Handed Interaction Operation concept like the one I submitted.
    https://www.youtube.com/watch?v=IxHRbaaU90I
    Additionally, (as part of my entry) I included a spreadsheet document listing all the minimum requirements from the specifications of the challenge. I would also invite you to fill it up as a reference. I have updated the document with the finalists, ready to be completed. You can download it here:
    http://we.tl/xdrwvuOete
    Thank you.
    P.D. My entry:
  • 3D concept
    Great entry Marcelo
    Now if all the entries were of this standard we would have nothing to say
    Did you look at my last entry with the modified seat rail, take a look at the "How it works GIF" I think you will like it.
    http://grabcad.com/library/nasa-champ-v5-with-new-seat-track-optimized-for-3d-printing-with-up-to-6-times-more-resistance-1
  • Tim Moss
    Congratulations to the finalists. Like the other submitters that didn't make the list I am of course disappointed. I am wondering if there was any consideration to the timing of the submissions. It appears that some of the finalist designs built off of or were very similar to earlier designs. Collaborative design is desirable in the workforce to generate the best result. However, in a competition, perhaps it would have been best to show the designs only after the submission deadline had passed.
  • Ben Ewing
    Thank you for the feedback everyone. We had a lot of amazing entries and deciding amongst them was very difficult. The finalists were selected based on the CHAMP figures of merit including the Total Material Usage, the Number of Prints Required to Complete Each CHAMP, the Handrail Connection, and the Seat Track Connection. As we go forward with the process and select the 5 winners, we be looking at these entries in depth and ranking them based on these metrics. When we release the winners we will offer more comprehensive comments regarding why each of the winners was selected. If you have any other concerns, feel free to contact me at ben@grabcad.com.
  • John Harald Schjelderup
    John Harald Schjelderup over 10 years ago
    Hi. I wasn't really planning to get involved in the discussion above, but I strongly agree with the earlier comments regarding the fact that "printability", compliance to specification and the time of design submission has not been weighted as deciding factors when selecting finalists.
    If I should participate in future GrabCAD challenges then I will wait with submitting my design up until the deadline to be on the safe side.
    Anyhoo, I wish the finalists the best of luck and you are already winners as far as I am concerned, well done!
    John Harald Schjelderup has uploaded 3 CAD models & has left 15 comments.
  • Matt
    Everyone would like to have his design chosen, but there we're 485 entries. I'm sure they chose good ones even if the best ones maybe we're left out. But you have to know even the best product won't sell if the advert is no good. And the entry had to be complete allround because this is not a kindergarten but a community of hungry wolves. It's a competition.
  • Jonathan Brazeau
    just a reminder to the community, if you feel there is a post that is really off the deep end, you can hit, "report spam" on the upper right.
  • Jonathan Brazeau
    I'm a fan of Mark fuller's and Micheal Heberts designs.... anything using pins printed in the Z direction I couldn't support, both Mark and I have learned this through the research process on our own designs, they WILL hold weight, just not for long.
  • Ben Ewing
    Again, I would like to thank everyone for their feedback. If you have any concerns, please email me at ben@grabcad.com. I would like to keep any further comments on here constructive and positive. Since I feel like we've covered all that needs to be said regarding the selection process, any further discussion on this topic will be removed. Let's remember that all of the finalists worked very hard on their submissions as well!
  • Mark van de Hei
    Mark van de Hei over 10 years ago
    I can't believe this reactions here. 'doesn't fit in the printer bed', 'doesn't interface', 'doesn't have some requirements' 'has to be modified' etc. Nasa has chosen the designs based on working principles, details are not important! Neither of the designs will be perfect and can satisfy NASA's demands. They will have a look at the working principles and the possibility of combining some (smart) features of the designs in a next level future champ. Congrats to the 14 finalist, and for the ones that were jealous in the previous comments: try to be positive, it was a nice competition and I'm sure that you've learned a lot from the design that you've made or at least you can learn something from the other 484 design that were participating.
    Mark van de Hei has uploaded 5 CAD models & has left 9 comments.
  • Gerard O'Donoghue
    @Mark, Details are important, we are designers and engineers, that is what we do!
    Meeting the minimum requirements of a specification is the way we work and
    If we do not meet the criteria then so be it, we accept the outcome and move on.
    Otherwise we could be artists and small details would not matter.
    Constructive comments on the selected finalists was asked for and given but should never become unprofessional or personal. It begins to sound like a sore loser.
    Congratulations on being becoming a finalist, really well done.
  • Clix
    Congrats to the winners, to organizers and all participants!, its been so interesting to see so many "schools of thinking" at work :), its been a privilege to race with you guys :).......and most important ....let's move on :)
  • Mark van de Hei
    @Gerard, I totally agree with you that details are important in designs. But in this competition, a really clever design with an incorrect interface to the seat track can beat an other design that does meet the requirements, but has less clamping force or uses twice as much material. ( for an example)
    thanks for the congratulation b.t.w. :)
  • Michel Schon
    Michel Schon over 10 years ago
    Before I started with my concept I didn’t think about the restrictions of 3d printing but about the opportunities and advantages 3d printing enables. The “Nasa wrench” is the best example: it can only be 3d printed, not be made by conventional means and it can be used straight from the printer.
    With this inspiration, I tried to think “out of the box”, I designed prototypes and after a lot of testing and adaptation the “Project Rigel CHAMP” was the result. I already listed all the advantages of my clamp but I can also say that is one of a kind. (Feel free to comment my design)
    After the “sales pitch”: Think more about the opportunities of 3d printing. For example: Open community of designers, open source designs and a 3d printer on Mars :) There will be so much to design that everybody gets his design to Mars :)
    Michel Schon has uploaded 3 CAD models & has left 38 comments.
  • Manolo Valenzuela
    Manolo Valenzuela over 10 years ago
    - My idea was conceptually original (no one else try it).
    - Not required support material to print (I proved it)
    - It can be installed with one hand.
    - It complies with the requirements.
    - And YES it works.
    Either way I send you a "BIG-HUG". Clamp: Big-Hug
    Manolo Valenzuela has uploaded 75 CAD models & has left 44 comments.
  • Robert Dietz
    If there was one that can be learned from the NASA wrench, that is moving parts do not last long. ABS just wears out to easily.
  • Michel Schon
    @ Robert which clamp?
  • #David
    Hi all, I've downloaded a number of the finalists entries and made videos of my testing of them as I said I would, but stopped halfway through as, well...I'll leave it at that. I was going to release the videos on my own but decided instead to leave it up to the GrabCad community. I've just uploaded a project called "My NASA CHAMP Challenge Evaluations" that can be found here: https://grabcad.com/library/my-nasa-champ-challenge-evaluations-1 If I get 2/3 of the number of remaining entrants - 1(me) in likes for this model (which as of this writing equals 316 likes), then I will release the videos. That will mean, at least to me, that there are a significant number of folks who still do care about this challenge and in possibly making the jury's decision a bit more transparent. If not then that will be the end of it. I had thought that I personally would have gotten some answers as to why the jury picked what they did after going through this process, but was left with way more questions than I had anticipated. Maybe if the videos get a chance to see the light of day, someone may be able to answer them for me. That however, is entirely up to you guys.
  • Winston Jennings
    Can someone tell me why the entries number is moving down. First it was 493, then 492,485,480 now 476? Does this mean that entries are still being processed?
  • Jonathan Brazeau
    @ Dave, liked and commented.
  • Tommy Mueller
    Tommy Mueller over 10 years ago
    Ditto
    Tommy Mueller has uploaded 224 CAD models & has left 1842 comments.
  • Robert Dietz
    David can you test mine out?
  • Jonathan Brazeau
    Rob deserves to have his tested, he's been dealing with the outcome pretty badly...needs some positive reinforcement :P lol.... I kid there Robert
    keep me posted, if David doesn't do it, I might be able to help you out...
  • #David
    @ Mr. jentis that's because people are removing their entries in protest
    @ Jonathan and Tommy, Thanks
    @Robert, If the videos end up getting posted, I'll do yours as well.
  • #David
    Just so everyone is aware, the analysis that I did (am doing) is only regarding the first 2 minimum requirements outline by NASA for this challenge which are:
    1. Shall be capable of providing a rigid connection to the handrail as defined above.
    2. Shall provide a seat track interface as defined above.
    What I've found is that most of the finalist's entries that I have printed out and analyzed did not. It's that simple.
  • #David
    I must add though that that is not all there is to the videos, there are also some quite surprising things I did find with regards to the finalists' entries that are well worth looking at.
  • Robert Dietz
    Ah that's ok Jonathan I'm fine...I spent much more time modeling than I did typing trust me.
  • Jonathan Brazeau
    ok, up to you...I'm going over your model right now, ChampLock..wouldn't mind seeing what it can take as far as static load....yes...i'm obsessed with how much weight I can hang off of these things... from first glance, looks good, but there might be an area of issue. I'll attach a picture on the model page in a second or two.
  • #David
    Actually, I want to revise my previous comment. What I found was what APPEARS to be that most of the finalists' entries do not meet those first 2 minimum requirements outlined by NASA in the challenge. That is what I hopefully will be able to show everyone else so that myself and others can have an open and unadulterated discussion about this challenge and NASA's seemingly interesting selection process...if only a few people care, then what's the point?
  • Robert Dietz
    You never know David, those few people may actually be the ones who have to use this thing. Now i must get back to my real job,I will check in later....
  • Ivan Pankratov
    Well, first congratulations to all finalists!
    With 493 entries for a contest it,s clear that there are more workable solutions than could be chosen for final. In same time most participants believe their design is the best,myself included :), but it's not the reason to adapt a "sore loser" attitude. It,s unrealistic to expect from NASA to go trough all 493 entries in such short time and be unmistakable in their judgment. Meanwhile will wait for NASA more comprehensive comments on their winners selection and support #David initiative for an independent test, i guess it will help choose winners among finalists .
  • Kamen Rusev
    I would like to see my clamp printed too. NASA self locking symmetric clamp
  • Mart Berghs
    Mart Berghs over 10 years ago
    What a downer that negativity. Would also participated if the main prize was a baseball cap with NASA logo. I'm just afraid to express my joy, to be a finalist.
    F**t, Joepie....
    Congratulations to all finalists, am looking forward to the final result.
    Mart Berghs has uploaded 773 CAD models & has left 1085 comments.
  • Jonathan Brazeau
    NEW VIDEO!!!!
    since I placed in the finals, it was time to really put the strong man to the test...
    I did a 20 minute video where I do a few more weight tests which ultimately lead to me falling on my a$$. CHECK IT OUT!!
    static load test of 226 lbs!!! CONFIRMED! (3:20)
    testing the lever (5:36)
    static load test of 250LBS!! UNOFFICIAL, critical failure (11:30)
    damage assessment (13:20)
    https://www.youtube.com/watch?v=8YXGA_bC_hM&feature=youtu.be
  • Jonathan Brazeau
    not enough people designing for the fun of it and ENJOYING what they're doing...
    too many people going "ME" "ME" ME" and not "OUR".
    too many people trying to PICK APART designs instead of saying, YES, WE KNOW THE FINALISTS AREN'T PERFECT, LET's HELP THEM MAKE THEM BETTER.
    in my video I clearly show the weaknesses in my clamp design, is it perfect, no, is it a GOOD design that can withstand a helluva lotta weight and beating, YES.
    I'm lucky to have made finalist, but now, I'm calling on YOU to be apart of this and help make this clamp design, and some of the other finalists, the best they can be, stop saying "ME" "ME" "ME" and sulking, and let's work together with my design and the finalists to make them the best they can be.
    MY DESIGN IS YOUR DESIGN
  • Ivo Alberti
    Ivo Alberti over 10 years ago
    You are a big ... Jo, you did not hurt, as I see from the final ballet.
    Pe me you're the winner ... Bravissimo !!!
    Ivo Alberti has uploaded 348 CAD models & has left 4625 comments.
  • Jonathan Brazeau
    GRAZIE IVO..I'm fine...
    I guess I should probably add.. I don't condone anyone trying these sorts of tests, if you do, wear the appropriate safety gear and proceed at your own risk.
  • Ben Ewing
    Hi everyone. We will be releasing a list of honorable mentions when announce the winners. Additionally, I wanted to clarify one of the finalist designs. We mistakenly announced an earlier version of Gergo Graf's "The Grabber" as a finalist instead of his second version. The results page has been updated accordingly. I hope everyone is excited to find out who the winners and honorable mentions are soon!
  • Michel Schon
    "Over the next week, participants are able to voice their support or concerns."
    And a few finalists delete my posts, that's great! (But thx to those who answer)
    Handrail Clamp keyhole
    Simple new seat track. But the clamp has to be tested. The main problems I see are:
    1.How do you remove the clamp?
    2.Are these teeth printable with the resolution of the 3d printer?
    3.Wear of the teeth?
  • Mart Berghs
    @Michel Scho: Right I have removed spam comments of only two people, who complain about everything. And recommend/spam their own entries in the final submissions comments. I am that negativity and nitpicking a little tired.
  • #David
    Just 291 likes left...singlefonts you should get in on this, you're the first one I evaluate
  • Mart Berghs
    @David: Lol, have fun. Looking forward to the results.
  • #David
    then like the model
  • Michel Schon
    @ singlefonts: I never posted my own clamp and my comment are concerns about your clamp and not nitpicking or spam.
  • Julian Groeli
    First off, congrats to the finalists!
    It'd be great to get some constructive feedback about how I could have improved my entry. Thanks to NASA and GrabCAD for setting up this challenge. I had a great time working on it.
    Here's the link in case you missed it :)
    ISS CHAMP
  • Jonathan Brazeau
    Jullan, personally, I think yous should have made it to finals. I was expecting to see you there. Great process and presentation. Would have liked to have seen some real world testing though...
    Did you follow all the criteria properly, maybe there was some little thing that you missed that did you in?
  • Roger Couture
    The only one among those that you chose answers the criteria required in my opinion. Twist-N-Lock NASA Handrail Clamp is my choice because it is the only one whom you will like using and whom the exercised strength is adjustable. If you need a more beautiful design, it is easy to modify slightly. The mobile room part can remain on the first screw not to lose it. I'm sure you need a rotation mecanism in this 3d print challenge.
    Un seul parmi ceux que vous avez choisi répond aux critères exigés à mon avis. Twist-N-Lock NASA Handrail Clamp est mon choix parce que c'est le seul que vous aimerez utiliser et que la force exercée est ajustable. Si vous avez besoin d'un plus beau design, il est facile à modifier légèrement. La pièce mobile peut demeurer sur la première vis pour ne pas la perdre. Je suis certain que ce défi exige un mécanisme de rotation pour ce challenge d'impression 3d.. (Turn to be safe)
  • #David
    What happened to my 316 likes? I did need 316, right?
  • Julian Groeli
    @Jonathan: Thanks for the feedback, and you're right about real world testing. Love your latest R&D video. Good luck tomorrow!
  • Alberto Beretta
    Alberto Beretta over 10 years ago
    Alberto Beretta has uploaded 26 CAD models & has left 178 comments.
  • Alberto Beretta
    David post a video!!!!!!!!!!!
  • Ben Ewing
    Hi everyone. The winners for the NASA Handrail Clamp Assembly Challenged have been announced! Congratulations to the winners and to everyone who participated in this amazing challenge! Take a look: https://grabcad.com/challenges/nasa-handrail-clamp-assembly-challenge/results.
  • Jonathan Brazeau
    Thank you for the feedback! great challenge.
    Congratulations is in order to Michel Hebert! **applause!
    Well, very disappointed not know that since I have been, but waiting another contest for NASA anxiously.
  • Roger Couture
    Bon choix du 1er prix. Félicitations au gagnant Michel Hébert.
  • Ridwan Sept
    Ridwan Sept over 10 years ago
    great challenge. congrats to all winner
    Ridwan Sept has uploaded 220 CAD models & has left 1659 comments.
  • Matthew Davis
    Matthew Davis over 10 years ago
    I would like to say congratulations to all the finalist and winners. Also a special thanks to NASA for running such a great challenge.
    Matthew Davis has uploaded 1 CAD models & has left 19 comments.
  • #David
    #David about 10 years ago
    This thing still has me so bent.
  • Amr Samir  Mohamed
    Amr Samir Mohamed over 9 years ago
    Congrats for all winners,
    well done :)
    Amr Samir Mohamed has uploaded 0 CAD models & has left 1 comments.
  • Mart Berghs
    Mart Berghs over 8 years ago
