Can i open solid works modle file in solid edge ? if yes then how.
REgarding how to open different software file in different software
Accepted answer
You can open a solidworks model in other CAD programs by saving the model as STEP (.step or .stp), IGES (.iges or .igs) or Parasolid (.x_t or .x_b). In your case, since you're trying to port to SolidEdge I'd specifically try Parasolid.
0 Other answer
