Copy/Paste Method similar to BricsCAD?
Recently moved from BricsCAD to AutoCAD due to some work-related issues between employer and Bricsys.
One thing I do from drawing to drawing is copy/paste notes. BricsCAD allowed me to simply copy a text entity from one drawing and paste to the next without inserting a basepoint. It automatically placed it in the same location from the previous drawing. Is there a way to set this up in AutoCAD without any additional hotkey strokes. It was always a simple "Ctrl+C" > "Ctrl+V".
Edit: I was mistaken on my workflow process. BricsCAD did ask for an insertion/base point, but hitting the ENTER key simply pasted the items in their original points. See below:
select item (left mouse click)
ctrl+c (copied the selected item)
ctrl+tab (switched to the next drawing)
ctrl+v (pasted copied item)
enter (asked for insertion point, but "enter" defaulted to original insertion point)
repeat...
no where in that sequence of events did i ever specify a base/insertion point.
