software Help!!
hi, I am looking for a software that will help me go from 3d scan to 3d print. All we do is scan parts from customers and add or remove holes or cracks. then straight to print.
can you help with this?
For laser scanning I used Geomagics Control. You'll also be able to clean/repair the data in the same program. I liked the program, but you'll want to make sure it works with your scanner.
https://www.3dsystems.com/software/geomagic-control-x
