Tutorial how to make engine part 12
    open a sketch under the body and draw this sketch.( you can use convert entities command for circles)
    extrude the sketch 10 mm
    go to front plane and draw this profile
    mirror all bodies with using right plane
  5. Step 5:
    extrude the profile at each directions. after, use body-move-copy comman to translate body 15 mm on Z coordinate.
  6. Step 6:
  7. Step 7:
    extrude it up to top plane
  8. Step 8:
    open a sketch on the right plane. use convert entities command.
  9. Step 9:
    extrude the last sketch in two directions. direction 1 is up to body and direction 2up to purple surface
  10. Step 10:
    crop the body
  11. Step 11:
    go to under of the body and draw this sketch
  12. Step 12:
    use linear pattern command (95 mm gab) then extrude the sketch up to pink surface
  13. Step 13:
    make same things for other side
  14. Step 14:
    crop this parts
  15. Step 15:
    open a sketch front side and draw a 30mm radiused circle. then use cut extrude command
  16. Step 16:
    open a sketch on the cylinders. draw circles like this
  17. Step 17:
    use cut extrude command. enter volues
  18. Step 18:
    please follow next tutorial
Please log in to add comments
