Tutorial how to make engine part 18
Step 5 really through me for a loop, but I figured it out after about 20 minutes. I'm not sure what Aykut is saying about "show" in the feature tree but i couldnt make it work.
Here's what I found that works for me, hope it helps others out. Thanks again Aykut for making this learning experience possible!!
Select extruded boss/base, under direction 1 select "up to surface" and pick the bottom surface of the oil pan. Now click on "selected contours" and select the 8 pillars to extrude.
Again, select extruded boss/base, under direction 1 select "up to surface" and pick the deeper bottom surface of the oil pan. Now click on "selected contours" and select the 6 pillars to extrude.
