Tutorial how to make engine part 20
Small
Carter connection points
    use fillet command
    after, make fillet this edges
    draw a circle
    use linear pattern command
  5. Step 5:
    cut the body
  6. Step 6:
    use mirror command
  7. Step 7:
    open a sketc on blue surface and draw a circle like this
  8. Step 8:
    use linear pattern command..
  9. Step 9:
    draw a centerline and use mirror command
  10. Step 10:
    use cut extrude command
Please log in to add comments
