Tutorial: How to make engine part 32
CYLINDER HEADS
open a sketch on the shown surface
draw two circles
add shown line. it must be tangent with the circle that on the left and it must be coincident with the on the right circles top point.
add this line
add shown lines like before ones
use trim command
use skecth fillet command
add two circles
extrude it by 2 mm
we will make same things for this side. open a sketch and draw two 18mm radiused circles
Step 11:
insert these lines
Step 12:
use trim command..
Step 13:
use sketch fillet command then draw two circle like before.
Step 14:
extrude it by 2mm
Step 15:
now we will use cut-loft command. be sure that these sketches are shown
Step 16:
open cut-loft command and select the smaller circles for profiles
Step 17:
select the centerline
Step 18:
use cut_loft command on the other side.
Step 19:
make the guide lines parallel with the each other. if you don't do that, your cut-loft shapes will be irregular
Step 20:
select the centerline and confirm that
Step 21:
use right plane and mirror the cut-lofts
Step 22:
open a sketch on the shown face
Step 23:
draw two circles
Step 24:
add shown lines
Step 25:
use trim command
Step 26:
use cut-extrude command with shown values
Step 27:
make same things for the other side. you should use convert entities command and select shown edges
Step 28:
cut the body like shown
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-33
