Tutorial: How to make engine part 35
Small
CYLINDER HEADS
    open a sketch on the shown face
    draw shown sketch
    extrude it by 24 mm
    draw same sketch on the other side
  5. Step 5:
    extrude it by 30 mm
  6. Step 6:
    use fillet command
  7. Step 7:
    use fillet command for shown edges
  8. Step 8:
    open full round fillet command
  9. Step 9:
    select these faces
  10. Step 10:
    finally select this face and confirm that
  11. Step 11:
    use full round fillet command on the other side
  12. Step 12:
    fillet these edges
  13. Step 13:
    continue to use filleting
  14. Step 14:
    open a sketch on thee shown face
  15. Step 15:
    draw two rectangles
  16. Step 16:
    extrude it by 10 mm
  17. Step 17:
    open a sketch on the shown surface
  18. Step 18:
    draw shown sketch..
  19. Step 19:
    cut the body
  20. Step 20:
  21. Step 21:
    draw a circle
  22. Step 22:
    draw a circle on the other side
  23. Step 23:
    extrude it by 10 mm (2)
  24. Step 24:
    use fillet command (2)
  25. Step 25:
    use fillet command again
  26. Step 26:
    open a sketch on the same face and draw two circle
  27. Step 27:
    cut the body by 7 mm
  28. Step 28:
  29. Step 29:
    draw a circle
  30. Step 30:
  31. Step 31:
  32. Step 32:
  33. Step 33:
  34. Step 34:
  35. Step 35:
  36. Step 36:
  37. Step 37:
    draw a circle
  38. Step 38:
  39. Step 39:
  40. Step 40:
  41. Step 41:
  42. Step 42:
  43. Step 43:
    next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-36
Please log in to add comments
