Tutorial: How to make engine part 38
Exhaust and Intake Camshafts
use linear pattern command like shown
use body-move-copy command like shown.
use body-move-copy command like shown on the fourth body
use same command on the third body
use same command on the second body
move the fifth body
use same command on the first body
open a sketch on the shown face
use convert entities command
extrude it 20 mm
Step 11:
open a sketch on the blue face
Step 12:
draw a circle
Step 13:
extrude it 20mm
Step 14:
select all of bodies
Step 15:
use combine command. then save the 'intake crankshaft'
Step 16:
make sure that you saved the file.
Step 17:
edit the boss-extrude 2 feature
Step 18:
make the offset dimension 15mm
Step 19:
use save as command and save 'eghaust camshaft'
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-39
