Tutorial: How to make engine part 42
Intake valves
open a sketch on the front plane
draw a line
continue
add a line
add a centerline
continue the skech from lower side
continue the sketching
add shown line
draw a spline
draw the last line
Step 11:
use sketch fillet command
Step 12:
use revolve command
Step 13:
open a sketch on the right plane
Step 14:
draw a centerline
Step 15:
draw a circle
Step 16:
draw shown random lines
Step 17:
use trim command
Step 18:
use cut-extrude command
Step 19:
use move-copy command like shown
Step 20:
save the "intake valves"
next: http://grabcad.com/questions/tutorial-how-to-make-engine-part-43
