Tutorial how to make engine part 7
we will model a piston. try to draw a sketch like in the picture. most importand dimension is piston radius.
use cut revolve command
open a sketch on front plane and draw a rectangle
use cut extrude command and cut the body
open a sketch on this surface
draw this sketch with using mirror command
extrude it 40mm. then open a sketch on this surface
use convert entities command and select this surface
draw the shown sketch
use trim command
Step 11:
extrude 10mm and mirror it
Step 12:
open a sketch on blue surface and draw a 11mm circle center of it
Step 13:
cut the body
Step 14:
now you should use fillet command.
Step 15:
use dome command
Step 16:
piston is ready for now. follow next tutorial
