Tutorial - Modeling a Castle Nut in SolidWorks?
Here is the tutorial.
Top plane>>Sketch.
Draw this profile using polygon and circle.
Extrude it by 8mm.
Top face>>Sketch.
Draw a circle of 18.75mm radius.
Extrude cut with draft at 45º with flip side to cut checked.
Top face>>Sketch.
Make two circles of 18.75mm radius and 10mm radius.
Extrude it by 4mm.
Chamfer.
Step 11:
Select the outer edge. Distance = 1.25mm Angle=45º.
Step 12:
Front Plane>>Sketch.
Step 13:
Draw this profile.
Step 14:
Extrude cut through all.
Step 15:
Reference geometry >> Axis.
Step 16:
Select the circular face.
Step 17:
Circular pattern.
Step 18:
pattern the cut-extrude2 about axis1 6 times.
Step 19:
Chamfer the edges.
Step 20:
We have the part.
Step 21:
After cutting threads.
