Tutorial - Modeling Ring nut in SolidWorks?
Here is the tutorial.
Top plane>>Sketch.
Draw two circles of 18mm and 10mm dia.
Extrude it by 5mm.
Top face>>Sketch.
Draw a circle of 15mm dia.
Extrude cut by 1mm. Check the flip side to cut.
Bottom face>>Sketch.
Same circle with 15mm dia.
Same Extrude cut operation of 1mm flip side to cut.
Chamfer.
Step 11:
Select the inner edges.
Step 12:
Top face>>Sketch.
Step 13:
Draw this entity.
Step 14:
Extrude cut through all.
Step 15:
Reference Geometry>>Axis.
Step 16:
Select the circular face.
Step 17:
Circular pattern.
Step 18:
Uncheck the geometry pattern and about axis1 pattern the cut-extrude3 6 times.
Step 19:
We have the part.
