Tutorial - Modeling Capstan Nut in SolidWorks?
Here is the tutorial.
Top plane>>Sketch.
Draw two circles.
Extrude them by 10mm.
Chamfer.
Select both upper and lower edge. Chamfer by 0.5mm and 45º.
Reference Geometry>>Axis.
Circular edge.
Front plane and then reference geometry>>plane.
Offset it by 7mm.
Plane1>>sketch.
Step 11:
Circle of 2mm dia at 5mm.
Step 12:
Extrude cut it.
Step 13:
Inner face>>sketch.
Step 14:
While selecting face click convert entitites.
Step 15:
Extruded cut.
Step 16:
Extrude cut by draft at 60º.
Step 17:
Circular pattern.
Step 18:
Select both cut-extrude feature as the feature to pattern about axis1 6 times.
Step 19:
And we have the nut.
Step 20:
After cutting threads.
