Tutorial - Modeling Ring collar nut in SolidWorks?
![](https://d2t1xqejof9utc.cloudfront.net/members/avatars/29274/feed.jpg?1552114776)
Here is the tutorial.
Start SolidWorks in Part mode. Top plane>>Sketch.
Draw a polygon with one side of 25mm.
Extrude it by 20mm.
Top face>>Sketch.
Draw a circle tangent to the side of the polygon.
Extrude cut by 45º draft and check flip side to cut.
Bottom face>>Sketch.
Draw a circle of 36mm dia.
Extrude it by 6mm.
Face>>Sketch.
Step 11:
A circle with offset of 3mm.
Step 12:
Extrude it by 6mm.
Step 13:
Step 14:
Convert the edge.
Step 15:
Extrude by 6mm.
Step 16:
Top face>>Sketch.
Step 17:
Draw a circle of 25mm dia.
Step 18:
Extrude cut through all.
Step 19:
Chamfer.
Step 20:
Upper and lower edges.
Step 21:
And we have the part.
