Tutorial - Modeling Flower in Creo Element aka Pro/Engineer using Surfacing method 1?
Here is the Tutorial.
Sketch >> Top plane.
Draw a spline. Exit the sketch.
Sketch >> Front plane.
Use the spline (i.e. convert). Exit the sketch.
Draw a identical spline to that in 2nd step.
Now we have 4 splines.
Select one spline on top plane and one on front plane and then goto Edit >> Intersect.
Step 11:
This creates a 3D curve for these splines. Repeat the same step for other two.
Step 12:
Insert >> Boundary blend.
Step 13:
Hold CTRL and then select both curves.
Step 14:
Insert >> Advanced >> Vertex Round.
Step 15:
Select the surface.
Step 16:
Hold down CTRL and select both vertex. Press middle mouse button.
Step 17:
Now enter the trimming radius.
Step 18:
Now hide the interest1 and intersect2.
Step 19:
Step 20:
Draw a circle.
Step 21:
Extrude it.
Step 22:
While selecting the leaf goto Edit >> Trim.
Step 23:
Select the circular surface as the trimming object.
Step 24:
Direction of keeping be outside.
Step 25:
Hide the extrude surface.
Step 26:
Select the surface and then goto Edit >> Pattern.
Step 27:
Pattern it about axis 6 times.
Step 28:
Select the surface trim and then goto Edit >> Pattern.
Step 29:
It will automatically pattern for reference. Click OK.
Step 30:
Thicken the surface.
Step 31:
Select the thicken surface and then Edit >> Pattern. Same settings and click OK. All the surfaces will be thickened.
Step 32:
Step 33:
Draw this sketch.
Step 34:
Revolve it and we have the flower body.
