Tutorial - Modeling Flower in Creo Element aka Pro/Engineer using Surfacing method 2?
Small
Here is the tutorial.
    Sketch >> Front plane.
    Draw this spline.
    Revolve it about the axis as a surface.
    Sketch >> Top plane.
  5. Step 5:
    Draw this profile.
  6. Step 6:
    Extrude it as a surface.
  7. Step 7:
    While selecting the revolved surface goto Edit >> Pattern.
  8. Step 8:
    Select Extrude surface as the trimming object direction be inside.
  9. Step 9:
    Right click Extrude surface and then hide.
  10. Step 10:
    Select the leaf and then Edit >> Geometry pattern.
  11. Step 11:
    About axis 6 times.
  12. Step 12:
    Select the first surface and then Edit >> Thicken.
  13. Step 13:
    Thicken it.
  14. Step 14:
    Similarily thicken other surfaces.
  15. Step 15:
    Insert >> Revolve.
  16. Step 16:
    Click Placement and then define.
  17. Step 17:
    Select Front plane.
  18. Step 18:
    Draw this profile.
  19. Step 19:
    Revolve it.
  20. Step 20:
    We have the flower body.
Please log in to add comments
